VideoHelp.com Forum
Thread: BDrebuilder
    I have downloaded all the required data for BDrebuilder, more then once, always stops at audio, cant find audio.
    James Durkin
  2. Renegade gll99's Avatar
    Is your hdd NTFS with lots of space? The first time I tried to make a full disc DVD9, I mistakenly put the output on a fat32 formatted hdd and it stopped at the 4gb marker and continued with the next step but then of course it couldn't find the audio.
    There's not much to do but then I can't do much anyway.
    Thanks for the reply, my download stops about 2 seconds after it starts. Other programs have downloaded it , but they don't shrink to size to fit a DVD9. BdRebuilder does, but am having no luck.
    James Durkin
    i need help i cant open the Bd builder at all for downloading . i down load the patch and while opening it i get an error, i load the link ope the file , open BDbuilder and extract all file , then i open the main file BD builder i try to run the program and i keep getting this message - ( component 'MSCOMCTL.OCK'or one of it's dependencies not correctly registered;a file missing or invalid . ) i a so fustrated . i tried installing and insatlling all the attached files the BDbuilder needs or requires about 10 times and still no luck , can someone please help me i am no the brightest light in the show room lolol
  1. Problem with BDrebuilder
    By tarzan54 in forum Blu-ray Ripping
    Last Post: 20th Jan 2012, 19:45
  2. AMD CPU and BDrebuilder
    By wulf109 in forum Blu-ray Ripping
    Last Post: 18th Dec 2011, 14:19
  3. BDrebuilder stops halfway, help please
    By volam1 in forum Blu-ray Ripping
    Last Post: 24th Oct 2011, 18:41
  4. PowerDVD 7.3 and new BDRebuilder
    By dharper40 in forum Blu-ray Ripping
    Last Post: 7th Sep 2011, 07:23
  5. Imgburn alternative for BDRebuilder
    By SimonG156 in forum Authoring (Blu-ray)
    Last Post: 21st Jun 2011, 10:34
