whenever i try to encode with fft3dfilter the following appears
"i dont know what "bw" means", and when i get rid of "bw" it says
"i dont know what "bh" means"
can someone help me?
Results 1 to 11 of 11
Thread: fft3dfilter help
How did you get rid of the "bw" error, as you say? What is your script? Do you have the fftw3.dll in your system path (as required for fft3dfilter)?
Also are you using "bw" and "bh", or bw and bh (without quotes, as it should be)?
when i said i got rid of it, i just removed "bw" everywhere it appeared on the script, bw and bh dont have quote in the script
and yes i have fft3w.dll in my system folder
post your script
you mean that?Code:LoadPlugin("C:\Program Files\AviSynth 2.5\plugins\fft3dfilter211\FFT3DFilter.dll") FFT3DFilter(sigma=2.0, beta=1.0, plane=0, bw=48, bh=48, bt=3, ow=bw/3, oh=bh/3, kratio=2.0, sharpen=0.0, scutoff=0.3, svr=1.0, smin=4.0, smax=20.0, measure=true, interlaced=false, wintype=0, pframe=0, px=0, py=0, pshow=false, pcutoff=0.1, pfactor=0, sigma2=sigma, sigma3=sigma, sigma4=sigma, degrid=1.00, dehalo=0, hr=2.00, ht=50.00, ncpu=1)
Try using the default settings:
FFT3DFilter()
And where is the rest of the script? Do you make any other calls to other functions?
just LRemoveDust_YV12 and Deblock
Yes - all your parameters are defaults so is equivalent to FFT3DFilter()!Originally Posted by poisondeathray
I think your problem is with the "ow=bw/3, oh=bh/3" bit. "ow" and "oh" should be integers, not expressions. "Divisible by 3" is the default parameter anyway, so again, just use FFT3DFilter().
Have a good read here!
Actually, they can be expressions, (you could have 16/3) but the problem is that "bw" is not a script variable, but a named function parameter. Avisynth tries to evaluate it before passing it to FFT3DFilter, but cannot.Originally Posted by ZQX
But as ZQX's link explains, the 1/3 ratio is the default, so you can just omit them from the call.
The same problem also occurs in the original call with the parameters
where sigma would be unrecognised (like bw and bh).
The confusion comes from misinterpreting the documentation. Where it says, for example, that the default value of ow is bw/3, this means that if you don't provide a value for ow, its value will be one third of the (supplied or defaulted) bw parameter. However, you cannot literally write "bw/3" as the value, since bw does not exist as a variable in the script.
As has already been pointed out, all the values used correspond to the defaults anyway, so a simple FFT3DFilter() will suffice here.
