VideoHelp.com Forum
    I converted several DVDs to MKV files using MakeMKV. No problems.
    I've used Handbrake to convert several files to differing formats. No problems.
    But when I use HB to convert (shrink) files created with MakeMKV to smaller MKVs, it get choppy audio...every time.
    I've tried every audio option available and every preset as well, always with the same results. Also, I've attempted to view the videos on four different players.
    In my infinite wisdom, and in a fit of frustration, I deleted all of the non-working files, so no MediaInfo to post.
    Has anyone else run into this issue? I've seen a few posts with similar problems, but never the same problem.
    Thank you for any assistance y'all can provide.
    Tried another converter? Xvid4psp, Ripbot264, format factory, etc.
    Have you tried copy/passthrough the audio? It should be possible in latest handbrake I think.
    Do you get same problems then?
    Microsoft Security Essentials went crazy when I went to install Format Factory...going to give Ripbot264 a try.
    (some sort of trojan clicker...)
  4. Member usta's Avatar
    Hmm... I have no problem with Format Factory installed on two PCs: one has NOD security and the other Microsoft Forefront client security.
    The new version of Handbrake fixed whatever was causing the issue. I have to admit, MakeMKV and Handbrake are two very awesome programs.
    Belay my last...I was mistaken.
    Handbrake still hates the movie (Disney's Atlantis) that I ripped with MakeMKV. Turns out just about everything hates the movie. DVD Shrink gives me a .VOB with an AR of 1187x328 (or something very close to that...going from memory here), and RibBot gives me nice big green blocks intermixed with the video to watch. Every other movie I've converted using MakeMKV/Handbrake/DVD Shrink has worked beautifully.
    The only thing that has "worked" is going straight to .MKV with MakeMKV, but that of course gives me a file size of about 3.1GB, and I'd like to get it down to around 1.8GB.
    Not a big deal, not going to worry about it any longer....
    BTW...setting up my new WDTV Live took less time than me figuring out how to set the alarm on my watch...great little media player.
  1. Handbrake encode won't start - one particular file
    By Stuckster in forum Video Conversion
    Last Post: 6th Mar 2012, 13:23
  2. how do I get makemkv to make movies that the PS3 can play?
    By Onceler2 in forum Newbie / General discussions
    Last Post: 14th Mar 2011, 04:12
  3. Problem with Makemkv, Handbrake and TSmuxeR, only getting half file!
    By Capt_Blackadder in forum Blu-ray Ripping
    Last Post: 19th Jan 2010, 11:30
  4. Using MakeMKV then Handbrake - adivce on creating MKVs
    By johnnyturbo3 in forum DVD Ripping
    Last Post: 3rd Jun 2009, 02:04
  5. Replies: 0
    Last Post: 8th Mar 2009, 20:56
