VideoHelp.com Forum
    hello
    avi is not showing in subtitle workshop no video just audio
    can any one help me please
    Hello to evry one
    You might be able to reset the video codec by using fourcc and setting the video to divx.
    Else you might try transcoding the video using virtualdub, or handbreak.
    thank's is working now
    Hello to evry one
    1. Which OS do you use?
    2. Have you installed any codec pack?
    3. If you use DVobSub 2.37, uninstall it and try using an earlier version (2.23, for example). This is a known problem (I had experienced it myself in Vista and Win7 recently). If the problem was not solved, uninstall DVobSub and install ffdshow and Haali Media Splitter. You can use ffdshow to show the subtitles in your player.
  1. Replies: 8
    Last Post: 30th Dec 2011, 12:58
  2. Replies: 0
    Last Post: 14th May 2011, 03:09
  3. Replies: 10
    Last Post: 19th Apr 2011, 15:37
  4. Replies: 0
    Last Post: 26th Mar 2009, 06:57
  5. Replies: 1
    Last Post: 11th Nov 2008, 22:16
