VideoHelp.com Forum
  1. Member RogerTango's Avatar
    Ive searched and cant find the command line arguments to fixvts so I can use it in my script.
    Can someone please post the arguments or a link to them?
    Thanks much in advance!
    Andrew
  2. Member AlanHK's Avatar
    Just look inside the exe, in clear text near the end.
    Or run it through strings.
    FixVTS: removes unused cells and corrupted packs from VTS, and updates the IFO files.
    Drag/drop a VOB to start.
    Command line arguments:
    FixVTS [-c] [-u] [-s] [-i] [-f] [-v] [-l LogPath] [-p] Filename.vob
    -c to empty backup before process.
    -u to remove unreferenced VCIDs
    -s to start processing immediately.
    -i to process "in place"
    -f for full DVD processing
    -v to not renumber VobIDs
    -l LogPath to save log to LogPath
    -p to fix bad PGC lba pointers
  3. Member RogerTango's Avatar
    MANY THANKS! Your a life saver!
    Andrew
  1. How to Use x264 Command Line
    By Jeff B in forum Newbie / General discussions
    Last Post: 20th Dec 2011, 15:56
  2. avidemux2 command line help
    By Choller in forum Editing
    Last Post: 31st Dec 2009, 05:17
  3. Command-line command for fixing AVI?
    By timur in forum ffmpegX general discussion
    Last Post: 23rd Sep 2009, 02:23
  4. command line
    By exekutive in forum ffmpegX general discussion
    Last Post: 1st Jun 2008, 23:44
  5. Access to command line
    By ktwbc in forum ffmpegX general discussion
    Last Post: 1st Dec 2007, 12:31
