My New Player Support sub/idx Subtitle,but it doesn't care about real color of subtitle.It put his own color to subtitle and its horrible.it make the background orange,make the shadow and the outline white and make the text orange too!!! it's the worst combination I've ever seen.
so please help me to cheat it and replace the colors
thank you
Thread: sub/idx color Problem
What player? software or hardware? What model?
sorry.Hardware.it's a portable media player.Originally Posted by poisondeathray
i think we have to fix idx file some how.but i don't know how to do it.Help me please
You can easily change VobSub colors using VobSub Configure (comes included with the VobSub package). But if your player doesn't honor the colors, that might not help.
that's exactly my problem.the player doesn't honor the colors.Originally Posted by manono
as I understood in sub/idx : color 1 is for Background,2 and 3 are for shadow and outline and 4th is for text.actually I'm looking for a way to change this sequence.it's a real challenge!!could you help me please?
Farsi is read from left to right, isn't it? If so, that's not correct. Here's a pic of the way I often make mine:Originally Posted by emfdom
Text is light grey. Anti-alias is dark grey. Outline is black. Background is blue and transparent. However, much more common is this:
where grey is text and black is outline, with the background (blue) and unused color (red) being transparent.
You can change the colors and transparencies with a combination of checking/unchecking the boxes and playing with the colors. If your background color is showing up when the subs are onscreen, then it's not the box on the right (blue with checked box in my example), but a different box. Unless you unchecked the box. Find out which box it is and check it to make it transparent.
I use, Patriot Box Office Media Player, I have this problem too.
I use SUB/IDX subtitle for my movies. When i add my subtitle it doesn't care about real color of subtitle. When i change it with Vobsub it's have the same color that has before change color.
What i can do about this?
Solved: Subtitles wrong color after converting from DVD to avi sub/idx
By jimdagys in forum SubtitleReplies: 4Last Post: 2nd Jun 2011, 02:38 -
Problem On Subtitle SUB/IDX format.
By ashkan_vpm2 in forum SubtitleReplies: 8Last Post: 5th Dec 2010, 23:22 -
How do I convert DVD to sub/idx or text srt COLOR subtitles?
By kkm in forum SubtitleReplies: 1Last Post: 19th Mar 2010, 13:08 -
idx/sub/sup problem when to be added to dvd
By StarX in forum SubtitleReplies: 4Last Post: 19th Jan 2009, 23:34 -
How to join the idx/sub languages ripped separatedly into just one idx/sub?
By Talayero in forum SubtitleReplies: 5Last Post: 29th Mar 2008, 08:58
