Hi, I had two files, one with a movie and the other with subtitles, I draged the subtitle folder in the movie file, so now I have one folder called sub, when I double click the folder there is 3 files now, the movie with .mp4 one has .idx at the end and the other has .sub if I play the movie on my pc I can see the subtitles ok, but if I burn the movie on to dvd I don't see any subtitles, I hope this makes sence I appreciate your help
Thread: adding subtitles to movie
The more you know the more you know that you don't know
BUT how did you convert it to dvd???? Did you add the sub/idx file?
I would use dvd flick, add the mp4 and the sub/idx subtitle file.
thanks for the prompt reply, I didn't convert it, I downloaded the file and burned with convertxtodvd, I think I've messed it up I deleted idx file thinking I only needed the sub file, will I have to download it again
You can also use ConvertXtoDVD(Yep, it's converting it to DVD). Load the mp4 and then also load the sub/idx under the Titleset->Subtitle.
Thanks I'll try that and report back
I did what you said, I could see the English subtitles in Convertxtodvd, but when it finished burning and I played it, I couldn't see any subtitles, what am doing wronge?Originally Posted by BaldrickThe more you know the more you know that you don't know
Did you enable the subtitles in the dvd player? (using your remote control or in the software dvd player). They are switchable dvd subtitles.
That did the trick, thank you for your time and help, Top man yourself
Movie freezes after adding subtitles.
By chickenwatt in forum Newbie / General discussionsReplies: 8Last Post: 8th May 2011, 07:09 -
Help with converting video / adding subtitles - subtitles are off from audi
By kurohoshi in forum Video ConversionReplies: 0Last Post: 27th Dec 2010, 15:53 -
Adding subtitles
By Avril in forum MacReplies: 14Last Post: 18th Jan 2009, 13:43 -
I need a guide fot adding subtitles to DVDR of series- not movie
By dallylama in forum SubtitleReplies: 4Last Post: 8th Jan 2008, 20:22 -
Adding subtitles to movie.
By dfisher052 in forum SubtitleReplies: 7Last Post: 4th Jun 2007, 09:30
