both record just fine ...I'm using a best buy hd tuner box on L2
but now have basic cable, but neither machine will allow me to fix the clock
and won't allow me to change from antenna to cable
the buttons are not grayed out, and there are no error messages
wtf is going on?
I've pulled the power cord before and it didn't help
maybe there's a dead internal clock battery that needs replacing b4 it'll respond?! eh?
Try holding down both the CH up and CH down buttons on the main unit for at least 10 seconds. The unit should turn OFF and revert to 12:00. This does a factory reset and will clear all your settings (but does nothing to HDD titles).
Both your models have TVGOS and it sounds like you've lost your TVGOS signal which controlled your clock.
jjeff,
thx
you nailed it!!!!
I better make a note on the set itself for the future.
Your TVGOS may or may not come back. Analog TVGOS OTA died with the analog shutoff although if you have a digital station broadcasting the TVGOS signal you may be able to use a DTVPal CECB to do the digital to analog TVGOS conversion for you. Cable is a different story, if they've stopped injecting the TVGOS signal in your analog cable (or have moved that analog channel to only digital which your Panny cannot tune) you're SOL
People are really starting to have TVGOS issues lately with cable and many have to resort to all manual events without the use of the nice TVGOS guide, good luck.
ya....the guide is toast
but my cheapo deluxe hd box has broadcast info
so it's no big deal...I don't record as much as I used to anyways
and basic cable is pretty much a waste
the channels I record are mostly broadcast....lol
the success truly was the time....so regaining control of that was the main deal for me
It sure would be neat to try to add a digital tuner ....but I don't have the time to try
How to add audio(.mp3) & adjust in video(.mkv) & burn in vbo ?
By ashe09 in forum AudioReplies: 0Last Post: 16th Jul 2011, 03:06 -
Adjust AVCHD mts file EXIF date-time
By cheerful in forum Newbie / General discussionsReplies: 1Last Post: 9th Jan 2011, 23:56 -
Panasonic DMR-EH55-Recording HD channels in full screen (16 x9)
By Marshfish in forum DVD & Blu-ray RecordersReplies: 6Last Post: 28th Dec 2009, 22:05 -
Panasonic DMR EH50 not picking up digital channels
By julie_152 in forum DVD & Blu-ray RecordersReplies: 1Last Post: 11th Dec 2009, 13:57 -
Panasonic DMR-EZ27 and EZ28 switches channels while recording
By dtsb52 in forum DVD & Blu-ray RecordersReplies: 1Last Post: 2nd Jul 2009, 11:59
