VideoHelp.com Forum
    HI
    I just purchased the HVR 1600. However the video has what I consider to be strong rainbows racing through it. Its hard to explain but is terrible. I updated my video driver and used both win tv 7 & sage tv with the same results. I am picking up analog cable. I also checked my cable coax line and it works clear with a tv hooked up. Any ideas?
    Thanks[/video]
  2. Member SHS's Avatar
    Bad Tuner
    I thought it might be but before I ordered this new card I first tried to hook up an old happauge card. Think it was the 250. It would freeze( not compatible with win 7) but I also remember the poor video rainbow effect. Was hoping to change some settings somewhere. Hope its not bad cause I ordered it off ebay from HK
  4. Member SHS's Avatar
    Check on the Tuner there a label dose it say NTSC or PAL
    If you got from HongKong I guesting that HK means for it?, most like a PAL ver which isn't for USA Cable system that maybe why your seeing the rainbow effect.
    Dose you problem look this see the short video clip in post 4#
    http://forums.sagetv.com/forums/showthread.php?t=19643
    I didn't know you were still around SHS. Nice to see you.
    Thanks for the replys. Yes that is what mine is doing but unlike the poster in that thread, mine stays that way. It does not clear up. Also the card does say NTSC. If anyone has any ideas they would be appreciated.
  7. Member SHS's Avatar
    Then most likey it is a bad tuner
    Yup I'm still a round lordsmurf
    Thanks for your help
  1. WinTV-HVR 1600 (video too dark)
    By jolu in forum Capturing
    Last Post: 22nd Dec 2010, 20:25
  2. Hauppauge Wintv-HVR-1600 ClearQAM VLC capture
    By rhijaen in forum Capturing
    Last Post: 25th Oct 2009, 20:53
  3. My new WinTV-HVR-1600 only shows B&W video
    By gigantibyte in forum Capturing
    Last Post: 20th Jan 2008, 10:29
  4. Hauppague WinTV-HVR-1600 Capture Capability
    By nebbish_2112 in forum DVB / HDTV
    Last Post: 17th Dec 2007, 18:07
  5. Replies: 7
    Last Post: 27th Sep 2007, 14:35
