I´m about to convert my dvd-collection to MKVs with softsubs.
Just wondering if there is any app that can encode the vobs and extract/merge the subtitles into the mkv container in one move.
Or do I first have to rip (dvd-decrypter), encode (handbrake), extract subs (subrip) and merge with mkvmerge.
A lot of steps when it´s over 700 movies.
Results 1 to 10 of 10
Thread: DVD to MKVs with SOFTSUBs
Handbrake can add the soft subs directly from the DVD. And you can install AnyDVD or DVD43 and you don't have to use dvddecrypter / dvdfab decrypter.
Do you have to re-encode the video?
A much simpler method would be to invest in more storage and to use MakeMKV. MakeMKV will rip the movie straight from the DVD and use the original MPEG2/AC3/Subtitle streams. It might take ten minutes at the very most for each movie.
Re-encoding might save a lot of space, but with 700 movies and 4 hours per DVD conversion, you are looking at almost 4 months continuous work...
Can only see one tab for subtitles in handbrake "audio & subtitles" and thats for hardsubs?
Whats the advantage of transcode to MKV vs leaving the vobs untouched.
I prefer re-encoding it because of the space. A lot of series and conserts as well (4-5 TB total) and I want to have it all on one disc.
Have two core2duos and one movie take 2 hours. In most apps you can queue and my computers doesn´t have much to do when I´m at work or gone to sleep.
The real time-problem occurs when I have to do several steps on each movie.
Ripping and re-encoding I can live with. But not 2 more steps just to get the subtitles.
As the previous guy have said the newest version of Handbrake can rip dvd to mkv with soft subtitles. It even tells you that is not "burnt in". Only if you convert to mp4 then it will be hard subtitles.
It will take you about 2 years at 2 hours a day to encode all the dvds to mkv with your present systems.To use makemkv it will take about 1.5 months at 4 hours a day.
Is the time it takes to encode worth saving space as to ripping directly?Ben Johnson-I didnt take any stereos!
Thanks guys! Downloaded the latest version of handbrake.
Space is really an issue for me. Have a hFX htpc chassi and it only supports 2 HDs.
2 Years?
Have 2PCs running at 4ghz.
1400h / 2 = 700h / 24 = 30days.
My calculations are correct,if you do one pass encoding 24 hours a day it will take 30 days,2 pass will take more than 60 days but encoding 24 hours a day on 2 machines means either you dont sleep much or work or you got some one to help and hope no glitches or o/s problems appear.
or you place a bunch of stuff in the que and let it do it's thing overnight..do the same while at work.
Setting up the que each time will also take some time......but at least you can sleep
I will rip the dvds first (and during encoding) and then que them offcourse.
Have a preset in handbrake and the computers will encode 24/7.
Tried to encode on my netbook aswell (eee1101HA) but I got an est of 15hours
How do i get meGUI to take softsubs?
By brotherhood1997 in forum Newbie / General discussionsReplies: 0Last Post: 7th Dec 2011, 12:26 -
Convert DVD ISOs to h.264 MKVs ?
By DButabi6 in forum DVD RippingReplies: 2Last Post: 4th May 2011, 00:27 -
ASS Softsubs Problem
By Mokkori Chan in forum SubtitleReplies: 17Last Post: 10th Apr 2010, 00:17 -
Alternative to softsubs for multilingual releases
By shorto in forum Newbie / General discussionsReplies: 1Last Post: 2nd Dec 2009, 02:19 -
how to get softsubs displayed??
By aruwin in forum SubtitleReplies: 2Last Post: 7th Oct 2008, 02:45
