VideoHelp.com Forum
    I've started using TMPGEnc Authoring Works 4 and it looks like a great app, but I'm stuck on one problem. I'm trying to create a menu from templates with a Top page followed by some Chapter Link pages. The Chapter Link pages are all fine, but I don't like the layout of the Top page - I'd like to add a background image to it of my choice and I'd like to add 2 text buttons called "Play" and "Scenes". I can add some text boxes but I can't work out how to link those to anything. I want "Play" to start playing from the start of the 1st chapter and I want "Scenes" to go to the first Chapter Link page. Does anyone know how to do this? It's very simple in DVDLab Pro, but I can't for the life of me work it out in TMPGEnc Authoring Works 4.
  2. Member Alex_ander's Avatar
    If you selected your template from 'Custom menu based on a template', then you can double-click on background and browse for background file source.
    Those can only be added at template selection stage. If your template is 'top+track menu' type then buttons for 'play all' and for track selection (Scenes in your case, if there's just 1 title) are created in top page. Button type (text in your case) is selectable with the template for buttons in the page.
    For scene (chapter) selection template you also define the number of buttons per page. Links to chapters are created automatically. You can only hide some unwanted buttons at editing stage, but the objects you add later can't be turned into buttons. Those are the limitations; also no menu transitions compared to DLP. But everything else in menu creation is easier and IMO better.
  1. Replies: 2
    Last Post: 11th Aug 2011, 15:32
  2. TMPGEnc Authoring Works 4 Menu Help Needed
    By VOYAGER2009 in forum Video Conversion
    Last Post: 15th Apr 2011, 12:37
  3. Menu question re: TMPGEnc Authoring works 4
    By jakewoodblues in forum Authoring (DVD)
    Last Post: 9th Jun 2010, 07:32
  4. TMPGEnc Authoring Works 4 - Menu help
    By NotSoEasy in forum Authoring (DVD)
    Last Post: 1st Mar 2010, 02:24
  5. TMPGEnc Authoring Works 4 Single Menu
    By Sakuya in forum Authoring (DVD)
    Last Post: 22nd Dec 2009, 02:04
