Is is possible my system drop frames because it's getting old?
I'm asking this because I'm using the exact same system as I did 2 years ago. No frame dropping for 2 years, suddenly it's dropping like crazy.
Here's my system:
Winfast Palmtop TV
ASUS P5GZ-MX motherboard (Intel Chipset)
Dual Core 1.6 GHz
1 GB RAM
WinXP Pro (clean install)
Onboard VGA n Soundcard (Realtek)
Which part is mostlikely be the problem?
Results 1 to 17 of 17
Stop cross-posting.
Oh sorry, I'm a little confused where to post.
Usually this is a Hard Disc problem. Also windows became "heavy" without maintenance.
So run a de-fragment on your hard discs and plan a clean windows install if that continues.
If it remains, you have a HDD problem, so you may have to replace it.
O ic. Which HDD should I check, the system's HDD or the target file's HDD?
Thx for the help
quanz, I've deleted your duplicate post. In the future if you want a topic moved, PM a Mod.
And in the future please use a more descriptive subject title in your posts to allow others to search for similar topics. I will change yours this time. From our rules:Thanks,Try to choose a subject that describes your topic.
Please do not use topic subjects like Help me!!! or Problems.
Moderator redwudz
Aye aye sir. Thx for the heads up.
You could also be dropping frames if your source is 29.97 fps and you're capturing at 23.976 or some different fps.
Ben Johnson-I didnt take any stereos!
Are you using an IDE hard drive? Is it running in PIO mode instead of DMA? Go to Device Manager -> IDE ATA/ATAPI Controllers -> Primary IDE Channel -> Properties -> Advanced Settings. See what the Transfer Modes are set to.
About 20 things to inspect: http://www.digitalfaq.com/guides/vid...ped-frames.htm
Answers to Common Video Questions:
Best blank discs • Timebase Corrector FAQ • Best VCR for capturing • Help restoring video
They left out a few other's which should be taken into account after 2 years
1: The possible impact of specific microsoft updates
2: Av upgrades / updates
I don't see how either of those could impact dropped frames or audio sync.
Why not put in more memory? 1gb isn't much.
I don't see how more RAM would necessarily help either.
Ok guys, I've de-fragmented the HDD and it improves alot, but still there's frame dropping (alot less). Now I'm trying scandisk for bad sectors. I'll let you know the results later.
Thx a million guys.
Try something like smart defrag, it's free.
The "new" Windows Firewall in Windows XP SP3 seemed to increase the number of dropped frames for me (i.e. created some where before I had none!).Originally Posted by lordsmurf
Cheers,
David.
Dropping frames on New PC
By beammeup in forum CapturingReplies: 9Last Post: 16th Apr 2012, 11:36 -
need help unblending previously blended frames rather than dropping frames
By BilboFett in forum Video ConversionReplies: 15Last Post: 12th May 2011, 21:15 -
WinDV dropping frames
By 2Bdecided in forum CapturingReplies: 3Last Post: 17th Oct 2009, 03:23 -
DivX Dropping Frames? But Why?
By Anakin in forum Video ConversionReplies: 5Last Post: 12th Apr 2009, 01:25 -
WinTV Dropping frames w/ new Dual Core AMD 5600+ system RESOLVED
By DAVE440 in forum CapturingReplies: 4Last Post: 26th Oct 2007, 21:01
