Hi.
Iīve done some back ups of blu rays with HDconvertTOx to x264 with MKV container,
but I would like to get the subs with too, to play on PS3.
Then yestoday I discovered the "Create Bluray structure" option, and tried that, and got the
Two blu ray folders, and burned it with IMGburn. But it doesnīt act like a blu ray when
I put it in PS3. Only says: Data disc, where I have to open the folders and gets no subs
selection. What do I have to do, to make it act like a "real" blu ray in PS3?
Should I patch it, or should I "create AVCHD structure" option instead, or what?
Please help![]()
You use bdrebuilder instead.
And I'm moving you to our blu-ray ripping and conversion section.
I did, but some movies dosntīt work in BDrebuilder.
Isntīt my first question possible?
If not, why the option then?
I've never used the Blu-Ray option in HDConvertToX. But I've made MKVs with subs. Look more closely at the subtitle tab and make certain you have checked *one* sub stream.
As to your trouble with BDRB, could you post a log file of a failed encode?Pull! Bang! Darn!
I can try, but i remember that it didnīt even start to encode.
The message was: Failed to retrieve audio!!
It was Casino Royale, with 2 english audio tracks,
and I get the same message from both tracks.
How long ago did you try? It may have been anydvd wasn't updated correctly to handle that movie. I have ran into that problem before. I just retried after anydvd had been updated a few versions and it took care of it.
My DVD backups are "invalid" in Sony Blu ray player
By KeithMckane in forum Authoring (DVD)Replies: 6Last Post: 26th Feb 2010, 15:11 -
DVDFab "Blu-ray to Blu-ray expired"
By Teutatis in forum Blu-ray RippingReplies: 15Last Post: 8th Jan 2010, 23:16 -
Samsung sued over "defective" first-gen Blu-ray players
By akrako1 in forum Latest Video NewsReplies: 11Last Post: 19th Feb 2008, 10:52 -
Editorial: Why "HD DVD" Is Thumping "Blu-ray Disc"
By Specialist in forum Latest Video NewsReplies: 146Last Post: 16th Feb 2008, 08:08
