I want to convert .m2ts files to MPEG2 using TMPG. How would I do this?
Thankyou
Results 1 to 10 of 10
Thread: how do you convert m2ts
what tmpgenc version?
It might be possible if you have codecs installed(ffdshow, haali media splitter) so you can play the m2ts directly with windows media player.
Or else could you try xvid4psp, format factory or prism and convert to a mpeg2 directly.
TMPGEnc 2.5
is it possible to frameserve to TMPGEnc? I really like having the control over the final video such as framerate and interlace ..etc
But can you playt the m2ts with wmp?
If so you can try install avisynth and the make a with text file with just
DirectShowSource("C:\test\video.m2ts")
and save as video.avs and open in tmpgenc.
If tmpgenc wont open it you can use HCEnc! It's another very good free mpeg2 encoder. Or use AVStoDVD, it might be able to open the m2ts directly.
WMP opens it and it looks good for a second then it gets all blurry,same with TMPGEnc it opens the avs file but the results are unrecognizable
HCEnc wont open it,I try from the avs
This is from a panasonic camera,I have had nothing but trouble trying to get these files to work in anything but HD Writer which came with my camera,it does convert to MPEG2 but does it interlaced which looks terrible
I had the same trouble with my Panasonic AVCHD footage, so now I convert to Canopus HQ - there's a free conversion utility here -although it will only work with the HQ codec installed. That usually only comes with Edius or Procoder, but the freeware version from here seems to work OK.Originally Posted by Onceler2
Canopus HQ is a high quality intraframe format, which is easy to edit - I still use Premiere 6.5 -- and then frameserve to Virtualdub, allowing you to add whatever filters you need - deinterlacing etc - before outputting using whatever codec you like. I get pretty good results using the vfw x.264 codec straight from Vdub.
I have read the mini guide by Soopafresh but it is for .mts files
Why convert m2ts to mkv ?
By dude905 in forum Video ConversionReplies: 5Last Post: 31st Jul 2011, 09:17 -
how to convert a m2ts to dvd
By splinter3217 in forum Video ConversionReplies: 19Last Post: 18th May 2011, 18:04 -
convert m2ts files
By dvd1304 in forum Newbie / General discussionsReplies: 1Last Post: 26th Sep 2009, 08:10 -
M2TS files - can I convert them ?
By Bansaw in forum Video ConversionReplies: 1Last Post: 10th Dec 2008, 10:32 -
Convert .m2ts?
By Bobd314 in forum Newbie / General discussionsReplies: 9Last Post: 27th May 2007, 02:55
