Where can i find this codec or a substitute for it?
Free Image Hosting by ImageBam.com
i have a avi that im trying to convert down in size just, and i must choose an audio codec for the output
and mp3 is the only alternative that sounds good? the problem is that the sounds dissapear if you convert 0162 to mp3
Thread: 0162 codec?
You forgot to search, http://forum.videohelp.com/topic3674...highlight=0162
But WHAT do you convert with? Virtualdub?
Sorry forgott that, im using "Video Convert Master" lolOriginally Posted by Baldrick
if you just lower the FPS down to 20-25 you get half sized files with good quality with this program
im not sure i can control that mutch with virtualdub and the endresult, the description howto in that other thread is a bit to rörig for my LQ brain here
convert video with Photo JPEG codec and MS IMA APMCD audio codec
By devil_doll in forum Video ConversionReplies: 3Last Post: 21st Jan 2011, 14:10 -
Can Codec ID/Codec Hint make a difference on the video?
By dzsoul in forum Video ConversionReplies: 2Last Post: 1st Jun 2009, 19:40 -
audio tag 0162
By lroixx in forum AudioReplies: 4Last Post: 8th May 2009, 00:07 -
MPG File with ivivideo Codec-bad picture.Can I change the codec?
By cska133 in forum Software PlayingReplies: 13Last Post: 4th Nov 2008, 09:41 -
BD Codec?
By kinglerch in forum Blu-ray RippingReplies: 4Last Post: 1st Aug 2008, 20:26
Statistics
Newest guides
Latest tool updates
New media comments
