VideoHelp.com Forum
  1. Member LSchafroth's Avatar
    Do I need to do any colorspace conversion when editing DV footage in Virtualdub?
    Lannie
    No, you can select "direct stream copy" if you're just cut/paste editing without any other processing.
    Cheers,
    David.
  3. Member LSchafroth's Avatar
    I will be doing some full processing with filters. Is it best to save back as dv before converting it to DVD or save to Lagarith Lossless? (spelling?)
    Lannie
    Depending on the processing, ideally lagarith - mostly to avoid going back to 4:1:1 chroma before going to 4:2:0 for DVD.
    Might not be very visible in practice when source was DV.
    For consumer DV footage, make sure super whites aren't being clipped by any conversion to RGB.
    Cheers,
    David.
  5. Member LSchafroth's Avatar
    thanks for the info David,
    I will experiment with the whites and levels.
    Lannie
    It may be hard to tell for sure if VirtualDub is crushing blacks and whites. You need to check them before VirtualDub gets ahold of the data. Use AviSynth's AviSource() and Histogram() filters. Make sure levels fall between the brown bars (a tiny bit above and below is ok).
    http://avisynth.org/mediawiki/Histogram
  1. New to editing with VirtualDub
    By xNesX in forum Editing
    Last Post: 18th May 2011, 23:56
  2. Editing FLV in VirtualDub
    By CursedLemon in forum Editing
    Last Post: 29th Jul 2010, 23:02
  3. Editing video with Virtualdub?
    By rosmari in forum Editing
    Last Post: 12th Nov 2009, 07:40
  4. Virtualdub, editing out faces?
    By capman21 in forum Newbie / General discussions
    Last Post: 2nd Mar 2009, 21:12
  5. mp3 editing with VirtualDub
    By tomchook in forum Audio
    Last Post: 2nd Jul 2008, 11:48
