I've been trying to produce a batch script to convert a load of MKV TV episodes to Xvid files that are compatible with my standalone DVD/Divx player, which can be quite fussy. The conversion works fine, and the output plays on my PC, but the standalone won't play it. I've tried to use the same encoding options with mencoder as I use with VirtualDubMod, which always gives me a playable file. Any ideas?
When I try and play the mencoder file on my standalone, the playback just freezes. Pressing the fast-forward button will skip through the video, but the moment I switch to play, the video freezes again.
mencoder command line (%1 and %3 are full paths to the input.mkv and input.ass files respectively):
"d:\avtools\mencoder\mencoder.exe" %1 -o "d:\cdtemp\cbb\fp.avi" -sub %3 -ovc xvid -oac copy -xvidencopts pass=1
second pass (%2 is full path to output file):
"d:\avtools\mencoder\mencoder.exe" %1 -o %2 -sub %3 -ovc xvid -oac copy -xvidencopts
pass=2:bitrate=1500:nogmc:noqpel:notrellis:cartoon :vhq=4:chroma_me
:min_iquant=1:min_pquant=1:min_bquant=1:max_iquant =31:max_pquant=31:max_bquant=31
:quant_type=mpeg:nopacked:closed_goprofile=asp5
Mediainfo of output file:
Mediainfo of input file:Code:General Complete name : D:\cdtemp\cbb\done\101.avi Format : AVI Format/Info : Audio Video Interleave File size : 344 MiB Duration : 24mn 42s Overall bit rate : 1 948 Kbps Writing application : MEncoder GIT-7bc18b7-4.3.3-Kovensky-mt 20091009 Writing library : MPlayer Video ID : 0 Format : MPEG-4 Visual Format profile : AdvancedSimple@L5 Format settings, BVOP : Yes Format settings, QPel : No Format settings, GMC : No warppoints Format settings, Matrix : Default (MPEG) Codec ID : XVID Codec ID/Hint : XviD Duration : 24mn 42s Bit rate : 1 495 Kbps Width : 720 pixels Height : 480 pixels Display aspect ratio : 1.500 Frame rate : 23.976 fps Standard : NTSC Resolution : 24 bits Colorimetry : 4:2:0 Scan type : Progressive Bits/(Pixel*Frame) : 0.180 Stream size : 264 MiB (77%) Writing library : XviD 1.2.1 (UTC 2008-12-04) Audio ID : 1 Format : AC-3 Format/Info : Audio Coding 3 Codec ID : 2000 Duration : 24mn 42s Bit rate mode : Constant Bit rate : 448 Kbps Channel(s) : 6 channels Channel positions : Front: L C R, Surround: L R, LFE Sampling rate : 48.0 KHz Resolution : 16 bits Stream size : 79.2 MiB (23%) Alignment : Split accross interleaves Interleave, duration : 500 ms (11.99 video frames) Interleave, preload duration : 500 ms
Any help appreciated; I'm also looking at other command line tools for xvid encoding, if anyone has any recommendations.Code:General Complete name : R:\cdtemp\cbb\101.mkv Format : Matroska File size : 587 MiB Duration : 24mn 42s Overall bit rate : 3 321 Kbps Encoded date : UTC 2008-05-20 11:04:57 Writing application : mkvmerge v2.2.0 ('Turn It On Again') built on Mar 4 2008 12:58:26 Writing library : libebml v0.7.7 + libmatroska v0.8.1 Cover : Yes / Yes Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : High@L5.1 Format settings, CABAC : Yes Format settings, ReFrames : 10 frames Muxing mode : Container profile=Unknown@5.1 Codec ID : V_MPEG4/ISO/AVC Duration : 24mn 41s Bit rate : 2 807 Kbps Nominal bit rate : 2 869 Kbps Width : 720 pixels Height : 480 pixels Display aspect ratio : 4:3 Original display aspect ratio : 1.500 Frame rate : 23.976 fps Standard : NTSC Resolution : 24 bits Colorimetry : 4:2:0 Scan type : Progressive Bits/(Pixel*Frame) : 0.339 Stream size : 496 MiB (84%) Title : Episode01: Asteroid Blues Writing library : x264 core 59 r851M e11ef38 Encoding settings : cabac=1 / ref=10 / deblock=1:-3:-3 / analyse=0x3:0x133 / me=umh / subme=7 / me-prepass=0 / brdo=1 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=0 / 8x8dct=1 / cqm=2 / deadzone=7,7 / chroma_qp_offset=0 / threads=3 / nr=0 / decimate=0 / mbaff=0 / fgo=15 / bframes=3 / b_pyramid=1 / b_adapt=1 / b_bias=0 / direct=3 / wpredb=1 / bime=1 / keyint=250 / keyint_min=25 / scenecut=40(pre) / rc=2pass / bitrate=2869 / ratetol=1.0 / rceq='blurCplx^(1-qComp)' / qcomp=1.00 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / pb_ratio=1.06 / aq=2:1.00 / zones=4000,4153,b=0.5/4154,4192,b=2/6580,6847,b=0.5/11803,11998,b=0.3/12348,12521,b=0.3/12666,12818,b=0.3/12947,13015,b=0.3/13037,13118,b=0.3/13387,14840,b=2/17712,17807,b=0.8/17832,17892,b=0.8/26967,27008,b=0.3 Audio ID : 2 Format : AC-3 Format/Info : Audio Coding 3 Codec ID : A_AC3 Duration : 24mn 42s Bit rate mode : Constant Bit rate : 448 Kbps Channel(s) : 6 channels Channel positions : Front: L C R, Surround: L R, LFE Sampling rate : 48.0 KHz Stream size : 79.2 MiB (13%) Title : 5.1 AC3 Language : Japanese Text #1 ID : 3 Format : ASS Codec ID : S_TEXT/ASS Codec ID/Info : Advanced Sub Station Alpha Title : ASS Language : English Text #2 ID : 4 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Title : SRT Language : English
Slainte
midders
Thread: Mencoder MKV to Xvid problem
After trying various options with mencoder, I finally gave up and found an alternative in xvid_encraw:
rem xvid encoding
rem first pass
"d:\avtools\xvid_encraw.exe" -i "%1\cdtemp\cbb\%3.avs" -type 2 -o "%otherdrive%\tmp\null" -pass1 -framerate 23.976 -progress 24
rem second pass
"d:\avtools\xvid_encraw.exe" -i "%1\cdtemp\cbb\%3.avs" -type 2 -o "%1\cdtemp\cbb\%3.avi" -pass2 -framerate 23.976 -bitrate 1250 -quality 6 -vhqmode 4 -bvhq -qtype 1 -nopacked -notrellis -imin 1 -bmin 1 -pmin 1 -progress 24
Since starting to use xvid_encraw I've developed a batch conversion routine that may be useful to others. More about it in this thread at MYCE.
Problem Opening h264 in VDubMod [MKV - XviD Conversion]
By catastrophe in forum Video ConversionReplies: 3Last Post: 1st Jul 2010, 18:13 -
SYNC PROBLEM: X264 AC3/DTS MKV --->>> Xvid with VBR mp3?
By Randm in forum Video ConversionReplies: 0Last Post: 3rd Jul 2009, 21:07 -
Mkv to Xvid 'length problem'
By bassam319 in forum Video ConversionReplies: 1Last Post: 2nd Jul 2008, 03:08 -
Problem: mencoder - mkv to avi
By Gordo_ in forum Video ConversionReplies: 2Last Post: 30th Jun 2007, 05:35 -
Converting MKV to AVI With Mencoder
By Startropic1 in forum Video ConversionReplies: 16Last Post: 25th May 2007, 18:03
Statistics
Newest guides
Latest tool updates
New media comments
rofile=asp5
