VideoHelp.com Forum
Thread: dts Bitrate
    Is there a way to convert dts 1510Kbps to 768 Kbps?
    I ask because since I bought a new LG Home Theatre system, every time I play a .mkv movie or a Blu-Ray disc with a dts soundtrack, it goes out of sync. 5.1 DD works fine. When I used MedianInfo to find out the bitrate I noticed all my .mkv's with dts have a 1510Kbps bitrate apart from X Men Origins: Wolverine. When I played this, it didn't go out of sync therefore, it must be the higher bitrate that causes the problem, so, if anyone knows how to change to a lower bitrate, it would be much appreciated 8)
    It would probably be easiest to just use popcorn mkv audioconverter and reconvert to ac3 5.1.
    I already use Eac3to to do that but, I want to keep the dts track for obvious reasons. My LG musn't be able to handle the higher bitrate, Wolverine has a bitrate of 755Kbps and doesn't go out of sync so it's just a case of finding out how to lower the bitrate, i'm having a go with Eac3to as I type but it doesn't look like it's working, unless i've done something wrong
  4. Member Noahtuck's Avatar
    I'm sure it has nothing to do with the bitrate.
    It probably got out of sync when it was encoded.
    Originally a member since 2001, LONG LIVE TARAN's!!!
    First of all, when you use a BluRay player to play MKV files, it's not going to work as well as a dedicated media player such as the Western Digital or similar models. There will be problems from time to time.
    MKV conversions are not always flawless. I don't do this sort of thing but I've read about what others have done and sometimes the frame rates get messed up between the audio and video if the person doing the conversion is not careful and this can cause sync issues. For example, the audio will be at 23.976 fps but the video will be at 24 fps (not 23.976 fps but really 24 fps) or vice-versa.
    I have never heard of any sync issue that was fixed by lowering an audio bit rate. It is possible to do what you propose, but I only know how to do it with commercial tools that you won't have. I suppose it might be theoretically possible that the decoding chip simply can't keep up with 1510 Kbps DTS in MKV and 768 Kbps really does work, but usually the problem is caused by the conversion process not being 100% correct.
    No, for 2 reasons, first of all, I have films that worked fine on my
    previous Home Theatre system which was a Sony and now doesn't
    work with the LG, secondly, i've encoded some films with the dts
    track included and it played fine on a friends Home Theatre but was
    out of sync on mine, i've phoned LG and i'm waiting for a call back from
    someone
  7. Unregistered El Heggunte's Avatar
    AC3 @ 640kbps is better than DTS @ 768 kbps.
    OR:
    1536kbps DTS --> 6 mono .WAVs --> (Surcode) --> 768kbps DTS
    (you may also need Eac3to for removing the SPDIF padding from the new DTS file).
  8. Member Noahtuck's Avatar
    well if it works on other equipment then obviously it's still not the bitrate but rather the equipment.
  1. How i can convert the dts-es or dts-ex 6.1 into dts core 5.1
    By fits79 in forum Newbie / General discussions
    Last Post: 29th Jun 2011, 22:30
  2. Replies: 0
    Last Post: 12th Mar 2010, 12:10
  3. DTS bitrate query..
    By anirban in forum Newbie / General discussions
    Last Post: 12th Nov 2008, 06:10
  4. MKV H264 bitrate reduction (also DTS to AC3)
    By Tooncis in forum Video Conversion
    Last Post: 2nd Jun 2008, 08:33
  5. DTS encoded disk, output to DTS receiver using an HTPC
    By ChipMcC1 in forum Media Center PC / MediaCenters
    Last Post: 18th Nov 2007, 07:06
