VideoHelp.com Forum
    I am new to this HD video.Im trying to capture to PPRO cs4 and not sure what settings to use.When I first start out I have my new project set to HDV after that it takes me to new sequence panel there I have selected the preset HDV 1080p30 (Im hoping this is correct) after this I go to the capture panel there I select where to put the video and I also select HDV.When I try to capture the video does not show on the PPRO preview screen but it does capture the video and run the camera from there.
    Just like to know if Im doing everything correct.'
    Thanks for your time
    Please post HDV in our DV/HDV forum. Moving you.
    in cs4 you cannot preview HDV footage in the capture window during capture. instead, the word capturing appears in this window during HDV capture process.
    only DVavi can be previewed during capture.
    only select the hdv30p template if you are shooting 30p, normal is 30i.
  1. Cannot capture HDV with Canon HV30
    By ChrisU in forum Capturing
    Last Post: 4th Mar 2012, 21:56
  2. AVCHD or HDV Capture in Premiere Pro CS4?
    By AjSVB in forum Camcorders (DV/HDV/AVCHD)
    Last Post: 2nd May 2010, 13:08
  3. Need Help Capturing with Canon HV40 to Premeire Pro CS4
    By JeffHDV7 in forum Camcorders (DV/HDV/AVCHD)
    Last Post: 18th Dec 2009, 23:01
  4. create DVD in premiere pro from canon HV30
    By yunakokimama in forum Authoring (DVD)
    Last Post: 22nd Jul 2009, 20:02
  5. Canon HV30 Video capture success
    By stevewolf31 in forum Video Streaming
    Last Post: 27th Apr 2009, 22:25
