does anyone have any experience with this device?
http://www.tracyandmatt.co.uk/blogs/...-player-review
i need something that plays back an HD .ts file - recorded from my Fortec Passion.
i need it to play an edited .ts of arounf 14Gb.
the raw stream is a .ts (and its the usual .h264 or whatever its called)
my xbox won't play em, and my pc, is too slow these days - bless it.
Don't know, but it will need to support NTFS to play 14GB files and the review makes no mention of this. That doesn't mean that it won't, but it would be nice to have said yes or no on this.Originally Posted by manikm
Your link is broken because you put a _ character in front of "http". Please edit your post and fix it like I did in my quote of your post.
cheers, some forums are fussy about "live" links, so that was the reason, ive now changed it.
im sure it supports FAT and NTFS.
im sure i read that somewhere.
im looking at the ASUS OhPlayer now.
I'm not trying to be rude, but after being a member here for 6 years you really should know already that we are not such a forum. All you do when you make that kind of post here is you make people angry and unwilling to help you because they think you are a moron who can't post correctly. Thanks for fixing it.Originally Posted by manikm
Look into the Western Digital WDTV Live. It supports NTFS and will play h.264 .TS files up to 1080p60. If you post a sample I'll test it out.
jman98: i think if you're honest, you know full well you are going out of your way to be rude, but worse than that, particularly unhelpful.
i'm sure anyone reading this will just think you are the moron and not me!
not sure if you're an admin, or not - but please, feel free to ban me if you think im out of line, as i dont want to be part of this forum if members like you are putting comments like that!
responses like that from jagabo are why i'm part of this forum.
jagabo: thank you VERY much! i will indeed look into it, as it appears it will indeed do the job required.
Problems playing 1080p files on VLC player
By Tafflad in forum Newbie / General discussionsReplies: 20Last Post: 20th Oct 2011, 16:29 -
media player 1080p vs 1080i
By mishtag in forum Media Center PC / MediaCentersReplies: 25Last Post: 11th May 2010, 23:25 -
Need help with list of High Definition 1080p Media Player
By crazydrve in forum Newbie / General discussionsReplies: 9Last Post: 8th Nov 2009, 18:57 -
Hi-Den Vision HDMI 1080p Digital Media Player
By minidv2dvd in forum Media Center PC / MediaCentersReplies: 0Last Post: 11th May 2009, 11:09 -
Problem playing wmv files in Windows Media Player and Media Player Classic.
By rayden54 in forum Software PlayingReplies: 4Last Post: 1st Aug 2008, 22:49
