If I convert a .mkv to DVD and the .mkv has built-in subtitles (NOT extra .srt files, but for example in VLC you go video> subtitles track> and you choose disable or the subs you want-- soft subs they call 'em IIRC), I can't cycle through this in any way on the dvd player, so the subtitles stay on screen the whole time
How can I alter this in the conversion process, to disable them? Right now I use DeVeDe for linux, I will try other apps/guides if I should.
Thanks for any help![]()
If the subs are "soft" in the MKV file then chances are they are in fact srt or something similar, but held inside the MKV file.
I assume the DeVeDe is encoding the files. Depending on how the files are being decoded, it may be that DeVeDe is seeing them with subs on screen, and encoding them as permanent (i.e. 'hard') subs on the finished DVD.
Your options therefore would be
1. Find out how to stop the subs being displayed to DeVeDe while it is encoding (probably a codec issue of some sort)
2. Edit the MKV file to remove the subs using mkvtoolnix, then encode
3. Find a smarter encoder.
[HELP][ANIME] MKV (H.264 + AAC) to AVI (PS3 - Compatible) with soft-subs.
By mooshimuushi in forum Newbie / General discussionsReplies: 4Last Post: 21st Aug 2010, 01:42 -
Adobe Encore versus soft-subs and MKV
By pc1971 in forum Authoring (DVD)Replies: 3Last Post: 3rd Jan 2010, 05:07 -
Backup DVD to mkv with soft subs
By rapaz in forum DVD RippingReplies: 28Last Post: 23rd Dec 2009, 23:16 -
How to convert MKV with soft subs to AVI using DVDFab 6.x
By Shilar in forum User guidesReplies: 0Last Post: 28th Aug 2009, 09:15 -
Help!!! Need to Convert Soft Subs into MKV to work with WDTV
By carlos1969-1 in forum DVD RippingReplies: 9Last Post: 6th Apr 2009, 11:17
Statistics
Newest guides
Latest tool updates
New media comments
