VideoHelp.com Forum
  1. I use AnyDVD to backup my blu-rays then use TSMuxer to strip all the junk from it that takes up an ungodly amount of HD space. Then use Imageburn to produce the ISO. Do I have to rip the Entire Blu-ray to my HD then use TSmuxer or is there a way to rip the Blu-ray with Anydvd running in the background straight through TSmuxer. My goal is to save some time from ripping the Entire Blu-ray. About an hour. (Its a slow drive)....
  2. Member fritzi93's Avatar
    Yes, with AnyDVDHD running, you can open the disc with tsMuxer. No need to rip first.
    Pull! Bang! Darn!
  3. Mod Neophyte Super Moderator redwudz's Avatar
    You should be able to open the BD stream file from the drive in tsMuxeR without ripping the BD disk to your HDD. If the main movie is on one .m2ts file, no problem. But if it's spread across a couple of .m2ts files, a bit more work. BDInfo should tell you the playlist info.
  4. Hmmm..I try to use BD info to open the disk but it gives me an error. Says the BD has an unrecognized file structure. If I rip the BD then it will work but that defeats my main purpose now..lol Yes ANYDVD is currently running in the background. I tried to use TSmuxer to read directly from the disk and it also gives me an error saying that windows does not recognize the disk....But all works well if I rip the whole thing to start useing Anydvdhd..Any ideas? Thanx!
    eac3to always works for giving you the main movie mlps
    ocgw
    peace
    Athlon II Propus 630 @ 3.62Ghz / 8GB DDR2 1066 5-7-7-20 / 8x BD-RW / 19TB Storage
    http://forum.videohelp.com/topic368691.html
  1. Backing up Blu-ray with Hauppauge PVR
    By Doc S in forum Blu-ray Ripping
    Last Post: 20th Jun 2011, 19:16
  2. Backing up my Blu Ray Discs
    By John75 in forum Newbie / General discussions
    Last Post: 6th Jan 2011, 20:27
  3. Replies: 9
    Last Post: 8th Oct 2009, 09:46
  4. Backing Up Death Race Blu-Ray
    By mr.adventure in forum Blu-ray Ripping
    Last Post: 14th Jan 2009, 10:18
  5. Noobie questions on HD/Blu Ray backing up and authoring
    By ryangarfield in forum DVD Ripping
    Last Post: 15th Dec 2007, 19:13
