Hey guys!
I'm new in the video capturing thing and I just bought a Pinnacle studio Moviebox Ultimate in the USA.
I'm from Brazil and to begin I already had a problem with the colors thing. All the captures turned out black and white because of the color system compatibility problem (we use PAL-M here). To solve that I bought a software that works as a transcoder. It worked but the video quality wasn't what I expected.
Someone told me that it would be easier and better to buy a DVD recorder to convert all my vhs to dvd.
My question is: wich dvd recorders are good and are they better than my Pinnacle studio Moviebox Ultimate?
If it's better I'll consider in selling my capture card...
Thanks a lot everyone for the attention and for the help.![]()
There will be a limited set of DVD recorders with a PAL-M tuner for over the air or PAL-M analog cable reception. You would feed this from your PAL-M VCR.
If you can purchase a dual standard PAL-M/NTSC-M VCR, you can output composite NTSC and capture that with your NTSC Moviebox. You might be able to find a dual standard combo VHS VCR+DVD recorder. These would only exist in the Brazil market since only Brazil uses PAL-M.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
Hmmm, ok.
But comparing the capturing quality, wich is better, moviebox's or dvd-recorder one? I'll use them to convert my old vhs to dvd...
tx! -
The MovieBox would be better for editing on the computer but to make that work you need a dual standard VHS player.Originally Posted by fabitos
A PAL-M native DVD recorder will do fine for simple cuts.Recommends: Kiva.org - Loans that change lives.
fabitos...are you sure you canīt switch to PAL when you set your capture properties within the Studio software?
It's a PAL-M specific hardware issue. If you switch to "PAL" the box expects Euro PAL 625/50 video with subcarrier at 4.43 MHz. PAL-M is 525/60 with subcarrier at 3.58 MHz. Pinnacle would need to specifically support PAL-M.Originally Posted by julitomg
Argentina also has a unique form of PAL called PAL-N. PAL-N is 625/50 with subcarrier at 3.58 MHz.Recommends: Kiva.org - Loans that change lives.
Well, I won't need to edit almost anything... those vhs are full with video clips, concerts and band performances... the maximum I'll need to do is to transfer to the computer and separate the performances/videos.Originally Posted by julitomg
I guess I'll have to find someone that has a DVD-recorder here and compare to my rip...
Thanks guys for the help!
Unable to create DVD using Pinnacle Studio Ultimate 14
By avz10 in forum Newbie / General discussionsReplies: 0Last Post: 1st Mar 2010, 09:06 -
Color Problems with Pinnacle Moviebox Ultimate
By fabitos in forum Newbie / General discussionsReplies: 5Last Post: 8th Aug 2009, 22:37 -
Pinnacle studio 12 ultimate - can someone tell me what this guy did please.
By photonianpa in forum EditingReplies: 7Last Post: 12th Mar 2009, 08:40 -
Can I capture DVD to edit? Pinnacle studio 12 ultimate
By photonianpa in forum EditingReplies: 1Last Post: 5th Mar 2009, 05:29 -
Pinnacle Studio 11 Ultimate ?
By AVCHD in forum Camcorders (DV/HDV/AVCHD)Replies: 3Last Post: 22nd Jan 2008, 13:08
