Good afternoon everyone. I've been looking for some info on the following. I have a MacOsX and am trying to stream m2ts videos to my ps3. I'm using a software called Eyeconnect 1.1 but for some reason, the ps3 will not display the m2ts files. it will only display .avi files from my mac. I've configured eyeconnect to read from a specified folder where my m2ts files are but the ps3 won't read it. I'm using tsmuxer to convert my mkv files to m2ts.
please let me know if i'm doing something wrong. thanks
Results 1 to 12 of 12
Thread: M2tS to PS3 on Mac
help please! if this is in the wrong section, can the mod please transfer this post to the proper section. thanks.
Moving you.
Have you tried PS3 Media Server ?
Baldrick, I just downloaded PS3 media server. My ps3 is able to see the m2ts files on my mac's HD but when I try to play it, it tells me that that file is corrupt, when the file isn't actually corrupt.
any way to work around this?
The PS3 gives the corrupt message for files it simply cannot play. It does not mean the file is actually corrupt. If the PS3 hits a file it knows it cant play it gives the Unsupported Data message instead.
First thing I would try is the Transcode option, to make sure that PS3MS can read the files and send them through.
The other questions is where do these files come from ? If the come from a camera, not all m2ts are created equally and can be played by everything. You may have to repackage them.
guns1inger, thanks for the reply. what is the transcode option? i clicked on the transcode tab and there are alot of options on it. what should I pick? As far as where the m2ts files come from, I get them from mkv files that I have converted to m2ts using tsMuXer.Originally Posted by guns1inger
On the transcode tab the main things to set are the audio (number of channels and bitrate) and the video bitrate. For wired you can go up to 15000 or so, for wireless I stick with around 8000.
When you connect on the PS3 end you will see a folder called trancode under the media server. Click on that and you will see your movies listed. Click on it, and it will tell PS3MS to transcode the movie.
As for your files - don't know. Other than to say that the original H264 in the MKV file must not be PS3 compliant.
I have not had this issue to date with any of the files I have played with, although I do find that none of the Apple trailers will repackage nicely for PS3 playback, and always need to be re-encoded.
gunslinger, how can i setup a wired connection from my laptop to my ps3 using this software? is there a tutorial out there that demonstrates how to do this. i have created some m2ts files from mkv files that I would like to see on my ps3 but they're over 10 gigs and will not fit on a dvd rl.Originally Posted by guns1inger
thanks
Same problem here... EyeConnect, unfortunately doesn't support .m2ts files.
What you can do is either:
1. Rename the file to .mp4, copy it to your PS3 and play it from there.
2. Download the very cheap (and, frankly, superior) MediaLink by NullRiver. This supports .m2ts files no problem.Last edited by m0thr4; 24th Mar 2010 at 16:35.
Try to stream the original mkv file with PS3MS, I do it all the time with no probs.
If it doesn't work the mkv must be corrupt.
Thanks for the suggestion, but the OP and I are using EyeConnect and, unfortunately, you can't run this and PS3 Media Server at the same time. If I switched to PS Media Server, then I'd lose the EyeTV-specific features that EyeConnect provides, so would inevitably end up having to change between the two on a regular basis. Remuxing as M2TS is a quick and trivial task, and of course in OS X, you can easily create a special folder that automatically renames the extension of your M2TS files when you drop them in (thanks Automator!).
The simplest way is to buy an ethernet cable and connect one end to your laptop and the other to the PS3. The PS3 has a Gigabit ethernet port, so if your laptop has the same, then you want to buy Cat6 cable (rather than Cat5) for best performance.
The you will need to configure up a new network for both your laptop and PS3 to connect to but, without knowing the topology of your home network (and whether or not your PS3 and laptop normally connect wired or wirelessly to your home router), I can't give any further advice at this stage.
Problem with subtitles on PS3 with m2ts
By Futterama in forum Video ConversionReplies: 5Last Post: 16th Oct 2010, 02:59 -
m2ts (vc-1) streaming to ps3?
By Browncoat in forum Media Center PC / MediaCentersReplies: 4Last Post: 16th Jan 2009, 02:06 -
Chapters and Subtitles on PS3 m2ts
By revhead27 in forum Newbie / General discussionsReplies: 2Last Post: 6th Oct 2008, 04:57 -
i need to split m2ts files for PS3
By domerdel in forum EditingReplies: 6Last Post: 11th Nov 2007, 02:36 -
Create m2ts for ps3 / muxer
By Thorax in forum DVD RippingReplies: 2Last Post: 17th Apr 2007, 16:11
