I will try to make sense out of what I am asking. I have video clips that I want to transition between each clip. I like to just drag each clip to about th 1.0 mark over the other clip for a neat look of a gradual fade into the next clip. Is there a way do the whole project at once or do I need to do this to each individual one at a time. I have about 2-300 clips so it will take a while other wise? Thanks.
Thread: Sony Vegas Pro question.
this isn't anything that a quick google search wouldn't have told you, but if you turn on /options automatic crossfades then whenever you add more then one video to the timeline at a time the effect will be applied. the /options/settings tabs have a place to control the length of the fade.
Yes, I am aware of that one but I think what I want to do is not going to have any easy out. I don't think there is a select all and apply it to all clips.
Another Sony Vegas Pro question.
By ingeborgdot in forum EditingReplies: 17Last Post: 9th Dec 2009, 12:42 -
Sony Vegas 8 Pro question
By ingeborgdot in forum EditingReplies: 2Last Post: 30th Nov 2009, 16:59 -
By ingeborgdot in forum EditingReplies: 9Last Post: 31st Aug 2009, 06:54 -
By ingeborgdot in forum EditingReplies: 2Last Post: 1st Dec 2008, 06:57 -
By ingeborgdot in forum EditingReplies: 4Last Post: 7th Sep 2008, 00:09
Statistics
Newest guides
Latest tool updates
New media comments
