VideoHelp.com Forum
    hello. I captured a movie from a tape that has really bad audio. It's muffled. Any way to improve things? Please let me know.
    thanks!
  2. Member Cornucopia's Avatar
    Here's one possibility: Inverse EQ
    Set the eq to match the inverse of what the current response is (you can tell this by a spectrograph/freq. plot)
    The resulting EQ will be flat (although you should NOT try too hard on the very ends/edges, they should dip down anyway)
    NOTE: This will ALSO boost up hiss/noise. That is to be expected - can you live with this?
    i can live with the hiss. I just wanna hear the audio so it's not like they're talking with a bandana over the microphone. Do you recommend any software to fix things? thanks for the help!
  4. Member Cornucopia's Avatar
    Any good audio editor app will do (particularly ones that accept DirectX, VST or other plugins):
    Audacity
    Adobe Audition (Cooledit)
    Goldwave
    Reaper
    Sony Sound Forge
    Digidesign ProTools
    Wavosaur
    even dbPoweramp and Nero's editor should be able to do that.
  1. Recorded sound really muffled HELP!
    By ethanfink in forum Audio
    Last Post: 20th Sep 2011, 17:41
  2. Remove muffled audio?
    By danilson in forum Restoration
    Last Post: 4th Jun 2011, 17:08
  3. Sony Vegas Pro 9 Sound is muffled
    By FEARL3SS in forum Audio
    Last Post: 6th Nov 2010, 17:29
  4. How to improve muffled audio
    By dexter30 in forum Audio
    Last Post: 24th Dec 2009, 11:17
  5. Audio Sounds Muffled
    By NBninja8 in forum Capturing
    Last Post: 25th Jan 2008, 23:53
