What is the best method to decode DTS without quality loss?
I have a WDTV and it cannot decode DTS, so I am looking for any other codec that I can decode DTS into. It will be then muxed into a MKV file with AVC video and played back as a video file. I just don't want any quality loss (or minimal quality loss) because dialogue is very important in the film.
Thanks!
Results 1 to 13 of 13
Popcorn MKV AudioConverter or MKV2AC3 and convert to AC3.
What are you going to be listening to the audio on ?
The audio will be muxed into a video file and will be played back on a WDTV.Originally Posted by guns1inger
Oh and doesn't converting DTS -> AC3 result in quality loss? How about DTS -> WAV is that possible?
Yes but I don't know if the wdtv supports multichannel wav.Originally Posted by m1ndripper
Why don't you try out 448kbps ac3 from your dts and see how it goes?
I don't think you have a pure lossless option with dts on the wdtv.
If you want to go that route you may have to consider investing in a bluray burner or m2ts files on a playstation 3.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
Matter of fact I do have a PS3
Will the overall file result in better quality than my mkv file I have? The file is 720p with DTS audio.
Is it really worth converting to .m2ts files?
As far as I know PS3 doesn't decode DTSOriginally Posted by m1ndripper
try to convert using Popcorn audioconverter or MKV2AC3
If you use MKV2AC3 just select a EMPTY DSTINATION FOLDER, select a AC3 Normalization, your desired bitrate....and go
it takes just a few minutes, you can then figure it out by yourself
Ok, I guess AC3 is the best option here. Hopefully there will be a minimal difference, converting 1500kbps DTS to 448/640kbs AC3 makes me cringe though lol but I guess its the best option.
In MKV2AC3 select 640kbps, and give a soft normalization, at least for my ears it sounds better
Then give your feedback how it sounds like
The WDTV is only passing the audio through to something else - an amplifier or TV. If you have a cheap amp or TV speakers (traditionally awful) then you won't notice the difference between DTS @ 1536 kbps and AC3 @ 448 kbps. However you can go up to 640 kbps for AC3.Originally Posted by m1ndripper
Ok thanks for your help guys.
I do have TV speakers lol, so thanks for clearing that up guns1inger. I am using Popcorn MKV AudioConverter and I was wondering, should I check the Downmix to Stereo box or should I just leave it as 6 channels? I will run the audio through TV speakers
I prefer to keep as much of the original quality as possible as the intention is always to get better equipment at some point in the future. If you downmix to stereo then you wont be able to come back to 5.1 later on without starting again.
However if this is more of a 'now' proposition, you might find that going to stereo is the simplest solution.
I'll just stick it out with 6 channel.
Thanks again
MKV & Adobe premiere: Best method to import without quality loss
By libjoe67 in forum EditingReplies: 34Last Post: 19th May 2012, 15:34 -
mkvmerge - no quality loss?
By gustav32 in forum DVD RippingReplies: 1Last Post: 20th May 2009, 14:56 -
Encoder with no quality loss
By JamesDV in forum MacReplies: 25Last Post: 8th Apr 2009, 11:01 -
video quality loss
By majax79 in forum Video ConversionReplies: 2Last Post: 24th May 2008, 01:03 -
Best quality telecine method for 23.976 -> 29.97fps
By DRP in forum Video ConversionReplies: 3Last Post: 11th May 2008, 08:37
