I have a Samsung BD P3600 Blu-Ray disc player which will not play back DVDs without freezing up if they come from 1ClickDVD copy. I have tried using both DVD+r DL and DVD-R DL discs that are of decent quality and it does not seem to make a difference. My laptop and desktop DVD readers can play these discs properly. The discs are copied one to one (everything with no compression).
Here is the strange part. If I were to use DVD Fab and use the "clone" option to get a bit for bit copy, it does not matter whether I use DVD+R DL or DVD-R DL discs. They ALL PLAY OK on the new Blu Ray player. So it would appear that 1clickDVDcopy is doing something that the player likes or is not doing something that the player expects. Whatever it is, DVDfab does it.
I know that the quick fix is to buy and use DVDfab, but what could be causing this behavior? I always are updating the firwware on this Samsung Blu-ray player whenever it is available.
Thanks for any guidance that can be provided.
Results 1 to 1 of 1
Same copied Blu Ray only reads sometimes in player, all the time with PS3.
By sevensees in forum Blu-ray RippingReplies: 8Last Post: 5th Mar 2012, 10:57 -
Samsung BD-D5300 Blu-Ray Disc Player
By kyrcy in forum DVD & Blu-ray PlayersReplies: 0Last Post: 27th Nov 2011, 14:09 -
Playing MKV - H264 in samsung blu-ray BD-C5300
By cwebdesign in forum DVD & Blu-ray PlayersReplies: 3Last Post: 11th Dec 2010, 14:42 -
Problem playing back Pixar's CARS Blu-Ray title
By javi270 in forum Software PlayingReplies: 1Last Post: 24th Jun 2008, 13:56 -
my player blu ray disk samsung bd-p 1400 not player my avchd on dvd-rw !?
By LEONESVIZZERO in forum DVD & Blu-ray PlayersReplies: 10Last Post: 4th Apr 2008, 09:15
