Can we enlists the opinions of knowledgeable users as to which HDTV brands, and models, have the best upconverting (scaling) characteristics in the screen size range of 26 to 40 inches? We wish to connect a DVD player that only has 480P capabilities and is not upconverting.
Thread: Good Upconverting LCD TV's
The best brand LCD's in recent history have been the Samsung, Sony and Sharp but other brands may contend model for model.Originally Posted by pepegot1
Each brand has a tiered level of deinterlace/upscale quality. Taking Samsung as an example, they have budget models found in Walmart, etc. (Level 3 or 4). Good models are offered as premium (level 5-6). Then super premium models 7-8-9 that also add networking and decode features.
At 26 to 40 inches, level 4 to 5 may be enough for budget buyers. At 40 inch up, Level 6 is a best buy then follow your wallet. A 40 inch TV can vary from ~$800 to $2000. Don't pay list.
Alternate strategy is to buy a premium DVD player like an OPPO and connect to a lower end HDTV (like Samsung level 4) at 720p, 1080i or 1080p. Problem is the superior processing applies only to DVD playback.
If you go the low end DVD player to high end TV route, you should test 480i or 480p as best interconnect. Let the TV do the deinterlace or inverse telecine plus upscale.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about
Please explain, or reference a site with an explanation of these levels. What is level 4 vs level 5, etc.?
Go with Samsung. You won't regret it. It's what I did and what my best friend and a neighbor did based on my recommendation and we're all pleased. I have an old 480p DVD player and it looks great on my TV. I have an LCD HDTV with 1080p and it's about 3 years old. Best purchase I ever made.
http://www.samsung.com/us/consumer/t...getype=subtype
Shows the levels and features per model.
If you search just for 40" models, you will see a choice of 9 models (Level 5 to 7) and list prices from $849 to $1799.Recommends: Kiva.org - Loans that change lives.
The levels relate to image processing engine quality. The lower your source quality (e.g. analog or SD 480i), the more benefit you will see from a higher level processor. DVD needs upscale. Blu-Ray discs require less processing and will look good on any of the levels. Higher level processors also offer 120/240Hz frame rate conversion to smooth 24fps judder.Originally Posted by pepegot1Recommends: Kiva.org - Loans that change lives.
Are either of these good LCD TN monitors?
By Stealth3si in forum Media Center PC / MediaCentersReplies: 8Last Post: 11th Jan 2011, 08:33 -
Good consumer LCD TV for VHS transfer without auto color/brightness
By OldMedia in forum RestorationReplies: 0Last Post: 1st May 2010, 01:02 -
Want to purchase good DVD Upconverting 2.0 USB Player in Canada
By scharfg in forum DVD & Blu-ray PlayersReplies: 1Last Post: 4th Jan 2010, 23:50 -
Is this a good LCD for 1080 playback?
By Engineering in forum DVB / HDTVReplies: 0Last Post: 16th Dec 2009, 16:42 -
What good browser is there for htpc use on a 32 inch lcd hdtv?
By yoda313 in forum ComputerReplies: 14Last Post: 21st Dec 2007, 08:25
