I am trying to make my first 1 to one DVD copy using a dual layer disc
Can I just do this
DVDDecrypter or Imagburn ->ISO Read->ISO Write.
or
Do i need to do something else
Thanks in advance
Ed
Results 1 to 15 of 15
Thread: 1 to 1 DVD copy
We were all NEWBIES once and the only stupid question is the one that's not asked?
That depends - are you trying to copy a commercial/retail DVD, or a home-made DVD?
i bought it on ebay but I think it is commercial made
It's a music videos dvdsWe were all NEWBIES once and the only stupid question is the one that's not asked?
Try ripping it with the free ripper portion of DVDFabDecrypter, then burn the results to the dual-layer DVD using Imgburn.
You may have mixed results if your dual-layer discs are made by anyone other than Verbatim, though, from others' experience here on VideoHelp.If cameras add ten pounds, why would people want to eat them?
You only need DVDDecrypter to do this, but may want to use ImgBurn for the burning part:
1. Open DVD Decrypter
2. Click "Mode"
3. Click "ISO", "Read"
4. Select Source
5. Rip to ISO file (select destination)
1. Click "Mode"
2. Click "ISO", "Write"
3. Locate the iso file that you just created.
4. Using Dual Layer discs, you will want to set burn speed low (i.e. 2.4X) - Burn.
Your copy is going to be an exact copy - down to any protections that were there also.
This method also works on DVD 5 originals.;/ l ,[____], Its a Jeep thing,
l---L---o||||||o- you wouldn't understand.
(.)_) (.)_)-----)_) "Only In A Jeep"
Well I tried it ...and it worked ! ...I used just dvddycrypter and memorex discs
thanks for confirming what I wrote classfourWe were all NEWBIES once and the only stupid question is the one that's not asked?
Ok well 2 out of three that I tried worked...I wasted 2 discs and don't want to waste anymore
any suggestions
Thansk
edWe were all NEWBIES once and the only stupid question is the one that's not asked?
Don't buy Memorex DL discs.Originally Posted by vcd4me
Originally Posted by guns1inger
Ok besides that
Honestly ? memorex DLs will, at best, give you about a 50/50 coaster ratio.
Only good combination is Imgburn with Verbatim +R DL blanks. Anything else is pissing away money in small increments.
I only use Verbatim DLs for the obvious reasons.
Stay away from the Made In India ones.;/ l ,[____], Its a Jeep thing,
Ok so even with the verbatim I am having problems it seems to be at the 50% mark they fail maybe this is the layer brake
Are there any settings that I should be using /changing in imageburn
EdWe were all NEWBIES once and the only stupid question is the one that's not asked?
not sure but at least 2 yrs old if not more ,,,However I literally just opened it this week
Ok so I can't figure it out not sure if it is aa drive problem or what
Well I just found out that my work laptop has a dual layer burner in it so I have made copies of all of them except one ...it keeps hanging up on one spot . Then I tried ripping them as vobs into my DJ software and it hangs up at a certain vob
so besides the imgburn method s is there another way to do this maybe with smart ripper ...I searched the guides and can't figure out what to use
EDIT
Ok sop I tried smartripper and it said some files maynot play try using a player ...I tried and sure enough the vob that it hangs up on won't play ...this now means I have a damaged discsright ...is ther anyway to make this work
DVDFab Blu-ray Copy vs. DVD Copy
By coody in forum Blu-ray RippingReplies: 1Last Post: 11th Oct 2010, 12:33 -
Copy of a Copy of a Protected VHS Tape to DVD
By solarblast in forum DVD & Blu-ray RecordersReplies: 12Last Post: 18th Dec 2008, 07:36 -
Is copy Sony PSP game same as copy DVD disc?
By coody in forum ComputerReplies: 10Last Post: 15th Dec 2008, 07:26 -
How can I copy a copy-protected DVD and have only ONE VOB file
By Aafour in forum DVD RippingReplies: 3Last Post: 6th Oct 2008, 00:31 -
Unable to copy copy-protected data DVD
By J_Kirk in forum ComputerReplies: 9Last Post: 22nd Jan 2008, 11:23
