hii there,
I got a tv with the native display resolution of 1366x768.
If I connect my ps3 to the tv, will the tv convert the signal from 1080p to 1366x768 ?
I amnt so sure about it since every seller jz call it as tv hd 1080p (KLV-26U300 26" BRAVIA Multi-System LCD HD 1080p)
I hope someone can answer my question.
You will need to download the manual or ask Sony whether the 1366x768 KLV-26U300 accepts 1920x1080p. 1280x720p and 1920x1080i would be accepted. PS3 games are mostly 720p native or less so 720p would probably look fine.Originally Posted by ivade-ragnarok
If you send 1080p, the PS3 must upscale to 1920x1080p, then the TV would need to downscale to 1366x768. This double scaling probably would result in a lower quality picture.
Another argument is most will never see a difference between 720p and 1080p on a 1080p native 26 inch TV unless you were significantly closer than a meter from the screen.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about
ivade-ragnarok, I've split your post off to a separate topic where you may get more answers. If you post in an existing topic, you want to address the original posters question, or better, start a new topic if your question is different.
And welcome to our forums.
All HDTVs will digitally upscale or downscale anything that doesn't match their native resolution. Even a matching input is usually upscaled to simulate overscan. The question is what input resolutions your HDTV supports. I believe all will accept 1280x720p and 1920x1080i. Only newer HDTVs will accept 1920x1080p.
the online specs say 1080p is fine for input.
Sony's NEW KLV-26U300A Flat Panel LCD Television with 1080p resolution HDMI and PC Inputs.--
If the video is 1080p to start with there is no upscaling needed,if the video is 720p and the ps3 sends it out as 1080p then its upscaled.Originally Posted by edDVBen Johnson-I didnt take any stereos!
1080P Playback On My PC? And WD 1080p Player Need A Expert!
By wpittsen in forum Newbie / General discussionsReplies: 2Last Post: 30th Sep 2009, 13:43 -
Playing 1080p video at 1366x768-does it downconvert to 720p?
By bigshotceo in forum DVB / HDTVReplies: 15Last Post: 28th Feb 2008, 15:54 -
Is it possible to convert 1080p to 1080i?
By kevlar69 in forum Newbie / General discussionsReplies: 4Last Post: 20th Dec 2006, 09:59 -
Does my A/V Receiver need to be 1080p HDMI to work with my 1080p LCD TV?
By thadbosley27 in forum DVB / HDTVReplies: 15Last Post: 16th Aug 2006, 18:01 -
DVD Player will it convert signal ?
By BSA250 in forum DVD & Blu-ray PlayersReplies: 4Last Post: 2nd Feb 2004, 00:01
