I am trying to use DVD Workshop 2 to create DVD of 8mm films. I used XP Pro for many outputs with no problems BUT after upgrading to Win7 Home Premium (clean install) I get NO sound while editing. After I generate DVD and playback on DVD player the sound is there BUT I would like to have control of sound while in the edit mode. I have DVDWS2 on two computers and they both act the same way. Anybody else having this problem?
Vista and W7 (I believe), handle audio much differently than XP did. When you R click on your speaker icon in the taskbar, does DVDWS2 show a volume slider when it is running?
You may have to go to the DVDWS2 website and see if the program has any updates for W7 or Vista that may apply. Or someone here may be more familiar with the program.
DVDWS is no longer being supported by Corel, which is sad.
Either build a XP PC for doing video work or move on to another program.
http://forum.corel.com/EN/viewtopic.php?t=35793
Is there another program LIKE DVDWS2 that will do everything WS2 does? I like the way I can delete audio, insert menu pages, insert audio and many other tasks. I guess I have gotten used to using WS2. I have looked at other programs and found them to be lacking in some form or another. Maybe I just have not "dug" deep enough into others...Originally Posted by MOVIEGEEK
Thanks,
Len
No. You'll need to build a legacy Windows XP machine, or emulate XP and DVDWS2 inside a VM (VirtualBox, VirtualPC, etc).
Nothing else like it exists.Answers to Common Video Questions:
Best blank discs • Timebase Corrector FAQ • Best VCR for capturing • Help restoring video
Audio-Video Capture on Win7 Home Premium Aspire 5334 Laptop
By vaudkid in forum Newbie / General discussionsReplies: 2Last Post: 16th Jun 2011, 23:26 -
[WIN7] 64 Home Premium & usb drive issues
By kenmo in forum ComputerReplies: 0Last Post: 3rd Jan 2011, 21:53 -
help with icons on vista home premium
By wingnut2003 in forum ComputerReplies: 11Last Post: 8th Jan 2010, 07:21 -
VFAPI problem on Windows Vista (Home Premium)
By foochuck in forum Video ConversionReplies: 1Last Post: 3rd Nov 2007, 18:10 -
DVX100B to Vista Home Premium - Nightmare!
By Tobuscus in forum CapturingReplies: 1Last Post: 13th Oct 2007, 13:34
