VideoHelp.com Forum
    Hi Guys
    My bro's business' website (conference recordings) has an option to purchase his DVD's or to download them, currently, the downloadable video size is half GB for just camcorder footage and 1 hour long, which is massive. I am looking into compressing this. After some advice i decided to go with mp4 H.264, but when i convert it with Super, i end up getting an even bigger file size. Could you's please look at my settings to see what i can do to bring the file size down. Would it be possible to get it down to about 70mb?
    Thanks a bunch
    Bigmaz
    Lower the Bitrate kbps setting. Use a bitrate calculator to calculate the bitrate to get exact output file size(se our tools list for video bitrate calculators).
    Or use another h264 converter like handbrake, xvid4psp and under the video settings can you set the file size directly.
    I get the following error with Handbrake (
    [12:02:49] reader: first SCR 0
    11 [unknown (0x1284)] HandBrakeCLI 1928 _cygtls::handle_exceptions: Exception: STATUS_ACCESS_VIOLATION
    22175 [unknown (0x1284)] HandBrakeCLI 1928 open_stackdumpfile: Dumping stack trace to HandBrakeCLI.exe.stackdump
    I have no ide why it crashes.
    But why not try SUPER again and lower the bitrate?
    Other simple free tools you can use are Format Factory and WinFF.
    Whats the best bitrate calc to use?
  6. I'm a MEGA Super Moderator Baldrick's Avatar
    VideoCalc or www.videohelp.com/calc , change to divx mode, set the running time and set the desired size.
  1. Converting fairplay protected m4v file(s)?
    By agent154 in forum Newbie / General discussions
    Last Post: 8th Apr 2012, 08:51
  2. Converting IFO file DVDs to M4v for Iphone viewing
    By anotherhappyday1 in forum Video Conversion
    Last Post: 22nd Feb 2012, 13:41
  3. Converting videos to m4v
    By Mc128k in forum Video Conversion
    Last Post: 4th Dec 2011, 02:37
  4. Converting M4V to AVI
    By tj3 in forum Video Conversion
    Last Post: 28th Nov 2010, 18:55
  5. Replies: 3
    Last Post: 14th Jan 2010, 00:17
