So now I just downloaded an .avi that has a .rar file with subtitles attached to it. I do I go about adding in the subs if needed? Are there certain programs I should use? Thanks in advance.
Thread: Adding subs to a .avi file
If they are .srt subs, just put them in the same folder as the video, named the same as the video, and your player should find them.
stgdlf, in the future please use a more descriptive subject title in your posts to allow others to search for similar topics. I will change yours this time. From our rules:Thanks,Try to choose a subject that describes your topic.
Please do not use topic subjects like Help me!!! or Problems.
Moderator redwudz
Got it on both the folder and the more descriptive subject, thanks.
[quote="redwudz"]If they are .srt subs, just put them in the same folder as the video, named the same as the video, and your player should find them.
So when you say "your player" does this include my PS3 playing my movies?
I don't know about a PS3, but with .srt subs, they are commonly put in the same folder as the video. That's the way it works with most software players and the few set top Divx/XviD players like the Philips 5990 that I have used.
Apparently not on PS3. I tried to put both the mp4 and the srt in a folder and it says unsupported data when I try to open it. Oh well. Thanks for the help though.
MP4? I thought you were attempting to play subs with an AVI?
(You don't have to convert an AVI to MP4 to play it on the PS3. Be sure you're using the latest firmware for the PS3, though. Also, if you want to add subs to an AVI for the PS3, you can try adding them to the AVI with AVIAddXSub.)
Edit: Oops - meant to say that you don't have to convert the AVI to play it on the PS3 if it has a DivX/Xvid video stream and an MP3 audio stream, for the most part.If cameras add ten pounds, why would people want to eat them?
Weird Problem - Adding subs to avi doesn't work okey on DVD Player
By andreas.cro in forum Newbie / General discussionsReplies: 5Last Post: 27th Mar 2012, 08:58 -
Adding subs to avi in virtualdub with textsub
By djgazzabhoy in forum Video ConversionReplies: 3Last Post: 26th Nov 2011, 05:04 -
Adding subs to avi format?
By Avon in forum SubtitleReplies: 2Last Post: 14th Aug 2011, 12:20 -
how to get correct aspect ratio when adding subs to avi file using auto GK
By neds81 in forum SubtitleReplies: 5Last Post: 29th Dec 2009, 18:01 -
Adding Subs to Avi
By ill_kuma in forum SubtitleReplies: 7Last Post: 9th Feb 2009, 20:02
