VideoHelp.com Forum
Results 1 to 9 of 9
    Sorry to say buy I dont like Videolan as much as media player classic so I want to use MPC to open my 4:2:2 Chroma videos is there a Filter codec to play them in MPC
  2. Member leghorn's Avatar
    Makes no sense to me so far... You dont like Media Player Classic, but you want to use MPC? MPC = Media Player Classic...
  3. I'm a Poll Super Moderator johns0's Avatar
    Makes sense to me,op rather use mpc than videolan and says so,as to chrome video not sure what codecs it uses as it isnt a standard name of video,need more detail on it.
    Ben Johnson-I didnt take any stereos!
    What's the fourcc? Directshow comes with YUY2 and UYVY handlers. MPC or MPCHC should be able to use them.
    4:2:2 are satellite transport stream files I capture from satellites, and I meant that I LOVE MPC and I HATE videolan MPC opens faster
    the
    and Videolan is the only one that plays 422 chroma files,
    will try directshow
    What's the fourcc? 4:2:2 describes chroma subsampling, not the codec used. Transport streams are probably MPEG 2 or h.264 with 4:2:0 subsampling. Use MediaInfo or GSpot. MPCHC as both of those built in. Forget MPC, it's outdated. MPCHC is the new version. It looks and works the same.
    hello can anyone download this short 13 se clip and tell me if you can open it in MPC or MPCHC its an 422 Chroma file, I CAN open in in videolan but not MPC or MPCHC
    http://rapidshare.com/files/309555696/422ChromaD155.mpg
    Please help
    What you have is MPEG 2 video in an MPEG transport stream (the extension was changed from .TS to .MPG). MPEG 2 encoding does support 4:2:2 chroma subsampling. And though it's uncommon, this file has it.
    MPC's and MPCHC's internal MPEG 2 decoder apparently doesn't support 4:2:2 MPEG 2. Disable their internal MPEG 2 decoders and use another. ffdshow works.
    THank you very much it works now
  1. Replies: 3
    Last Post: 24th Apr 2010, 11:23
  2. Problem using Media Player Classic home cinema player
    By True Colors in forum Newbie / General discussions
    Last Post: 18th Apr 2010, 07:30
  3. Streaming FLV in WM Player or Media Player Classic
    By jlz901 in forum Video Streaming
    Last Post: 21st Mar 2010, 11:09
  4. media player classic standard filter, setting it up
    By THX-UltraII in forum Newbie / General discussions
    Last Post: 19th Aug 2008, 17:31
  5. Replies: 4
    Last Post: 1st Aug 2008, 22:49
