I'm trying to create a DVD out of an AVI file using DVD Flick and ImgBurn but the sound turns out pitched down, causing the sound to be very slow and deep.
AVI specs
Video
Codec: DX50, DivX 5.1.1 (Maupiti), MPG4 (Codecs are NOT Installed)
Length: 1:40:30
Frames/s: 23.976
Audio
Codec: 0x0055 MPEG-1 Layer 3 (Codecs Installed)
Info: 44100Hz 128 kb/s tot, Joint Stereo
The settings in DVD Flick I've tried
Project settings/General:
Target size: DVD (4.3 GB)
Encoder priority: Below normal
Thread count: 1
Project settings/Video:
Target format: NTSC-film
Encoding profile: Normal
Target bitrate: Auto fit
Audio modification: 100% and 50% (the sound in the origial AVI is a bit loud)
Channel count: Auto and Stereo
Bitrate: Auto and 128 kbit/s
Project settings/Burning:
Create ISO image.
No menu.
Everything else has been the standard settings.
Why does the audio change the way it does when I create the DVD? I've played the ISO and the VOB files in VLC with the same result, while the sound in the AVI plays just fine.
The exact same thing happened when I tried avstodvd. I don't know what to try next, since the problem seems to be with the source AVI and it takes far too long to keep trying different programs.
Is it a good idea to create VOB's with just the video parts and add try to add the audio separately? I mean so that I won't have to wait another 2-3 hours just to see if it works.
And here is the problem in the log:
<11/20/2009 2:15:33 AM>
START AUDIO ENCODING OPERATIONS
Wavi+Aften Parameters: "C:\DOCUME~1\user\LOCALS~1\Temp\VASS_0_Les.avs " - | "C:\Program Files\AVStoDVD\Aften\aften.exe" -pad 0 -b 192 - "C:\Documents and Settings\user\Desktop\New Folder (3)\VASS_0_Les.ac3"
<11/20/2009 2:17:57 AM>
Problems encountered during Title 1 AUDIO encoding operations.
START (BACKUP) AUDIO ENCODING OPERATIONS
FFmpeg Parameters: -i "C:\Documents and Settings\user\Desktop\New Folder (2)\Les.avi" -y -vn -ar 48000 -ab 192k "C:\Documents and Settings\user\Desktop\New Folder (3)\VASS_0_Les.ac3"
<11/20/2009 2:23:16 AM>
END AUDIO ENCODING OPERATIONS
A2DAudioSource: FFmpegSource2 (cache off)
Created File: C:\Documents and Settings\user\Desktop\New Folder (3)\VASS_0_Les.ac3 (190.2 MB)
OUTPUT AUDIO INFO: AC3 - 192 kbps - CBR - 48000Hz - 1ch - 0 seconds
Not "VOB" files, but mpeg video.Originally Posted by yuh_learn
And yes, converting audio is much faster than video, only a few minutes per hour of audio.
Try eg ffmpeggui, which should produce a DVD-compatible AC3 from the AVI.
-- EDIT: from your error output, seems that won't work.
Then use an authoring app to combine the MPEG and AC3.
Eg, GuiForDVDAuthor.
If not, then there really is something weird with your AVI.
Try extracting the audio, eg with VirtualDub, or Avidemux.
Should be fixable, eg with an audio editor like Audacity, but you'd need to spend a while to learn the ropes.
Have you installed a decent audio directshow decoder? Like, i.e., ffdshow (stable releases)?
There is surely something weird about your AVI audio stream, because AVStoDVD tried:
1. to use DirectShowSource to access audio stream, failed -> shifted to FFMpegSource
2. to encode with Aften, failed -> shifted to ffmpeg -> null output
Bye
The over-night project worked out just fine.
I hadn't installed a decent audio directshow decoder, as far as I'm aware, but ffmpeggui managed to do the trick. What does ffmpeggui have that the DVD tools I used doesn't?
But since everything worked out, I just want to thank you for the help: thanks!
Hi pitched audio whine...
By bsuska in forum Newbie / General discussionsReplies: 1Last Post: 25th Mar 2010, 07:59 -
Audio slightly high pitched in any player...
By Guitar3dt in forum AudioReplies: 20Last Post: 26th Nov 2009, 17:24 -
no audio after converting avi to dvd
By dhyane in forum Newbie / General discussionsReplies: 3Last Post: 31st Aug 2009, 14:25 -
Old VHS tape turns slow...
By booksix in forum RestorationReplies: 5Last Post: 21st Nov 2007, 14:40 -
DVD audio sounds high pitched
By nopulse in forum Newbie / General discussionsReplies: 3Last Post: 19th Nov 2007, 19:31
