Hi guys,
I would like to ask you for some help.
I am trying to combine videos from several sources (webcams) then add some overlay images and text and stream the result live. The main problem is that text and images can be changed at any time and are not known in advance. So basically I must be able to add unknown staff to the video at any time (something like live sport events when they display results).
I was considering using AviSynth (pretty powerful staff). Problem is as far as I understand it can be used mainly for postproduction and not for live processing. I was hoping to find some plug-in for AviSynth (before trying to code one myself) that will allow me to add images and text "on-the-fly" but no luck so far. If anyone knows such a plug-in or function, please let me know. I'll be most grateful to you.
Can you tell me what other software/hardware I can you to achieve that? I prefer to be able to automate the process (i.e. the software/hardware does not require UI interaction) but will accept anything! I can code if needed (e.g. write a plug-in for existing software).
Any help appreciated!
Thanks in advance!
Sometimes it's possible to use ffdshow in between AviSynth and whatever program you're using to stream the video. You would adjust ffdshow's video decoder settings. There's a part where you can use AviSynth. Then you'd do something like:
Layer(last,ImageSource("overlayimage.png",pixel_ty pe="rgb32"))
But even if you could get it working (probably after much aggravation) it would be tough on the fly.
It's pretty hard to find a good free program that will let you use a custom image for overlays. You'll probably need payware here.
Thanks NerdWithNoLife,
I came to the realization that what I actually need is a Video Mixer SDK that I can use to program what I need. I'm currently investigating two such SDKs for Windows:
http://www.medialooks.com/products/m...er_object.html
and
http://www.datastead.com/products/tv.../overview.html
Both offers capturing from various sources, adding images, text, effects, etc. and then saving the video to a file or streaming it over the network. Not free, but will allow me to do what I want.
I should also say that using a SDK suits me better, because it allows me to obtain images and texts from any source such as XML file, web service, user input, etc.
Thanks again for your help.
I'll be back with more news about my progress for anyone who is interested.
How Can I Recover Overlay Images from DVD VIDEO_TS
By gary@tmi in forum MacReplies: 9Last Post: 13th Jan 2010, 21:15 -
How to overlay images on video frames?
By vace117 in forum Newbie / General discussionsReplies: 4Last Post: 19th Jan 2009, 13:48 -
Command line text overlay tool
By lmundy in forum LinuxReplies: 3Last Post: 13th Jul 2008, 13:58 -
Vegas 8: Overlay text in multimcamera mode?
By stantheman1976 in forum EditingReplies: 0Last Post: 4th Feb 2008, 13:08 -
Overlay still images on existing video, temporarily
By paros in forum EditingReplies: 11Last Post: 30th Aug 2007, 18:15
Statistics
Newest guides
Latest tool updates
New media comments
