I've been looking through all the guides on the site as i'm looking at streaming TV to a couple of machines on my network.
I would like to use the Windows Media Encoder 9 software to stream the live capture but was wondering if anyone could recommend a TV card that would be easy to set up and would work using this software.
Welcome Stevet1972
These are devices I have used with windows media 9 encoder> Avertv usb2, dvd maker pci gold, Leadtek winfast dtv 1000 T, WinFast drvr3100 H, fission usb2 dual dvbt... even the old asus 3000 / 3600 vivo's and fly 3000.
But as one can see there are many others ... with other features to consider
Hi BJS
Thanks for the reply the WinFast DVR3100 H looks ideal.
Thanks again
Recommend a <$100 capture card for analog to lossless AVI codec
By Cheesyii in forum CapturingReplies: 8Last Post: 27th Dec 2011, 08:49 -
Recommend Capture card/stick pls
By jubbely2 in forum CapturingReplies: 5Last Post: 27th Oct 2010, 12:14 -
Which card do you recommend for PAL capture to Huffy .avi?
By Chaoji3791 in forum CapturingReplies: 12Last Post: 13th May 2008, 17:52 -
Can anyone recommend a NTSC capture + video card based on this criteria?
By Rein Engel in forum CapturingReplies: 7Last Post: 5th Feb 2008, 07:25 -
Recommend AGP 4x capture card for P4 2.4GHz computer please??
By w@ntonsoup in forum CapturingReplies: 16Last Post: 9th Oct 2007, 11:05
Statistics
Newest guides
Latest tool updates
New media comments
