I ripped one of my BD movies with AnyDVD HD and muxed the film into an MKV using tsMuxer with no resizing or transcoding.
When I play back the MKV, which is 1920x1080 (the same as my desktop resolution) using Windows Media Player with ffdshow/Haali media splitter the video is squished vertically with black bars being added to the black bars already present in the 16x9 file.
I used RipBot264 to resize the MKV to 1280x720 and WMP played it back fine with no AR change. I've searched around and can't find a solution so I was hoping someone here could help me.
Does it look the same if you play with vlc media player?
You can try use mkvtoolnix and try change the aspect ratio and make a new mkv and see if it make any difference.
ANd you can also try use MakeMKV to make an mkv from the blu-ray. No conversion.
Osirus23,
I'm guessing that the 'extra' set of black bars were encoded in the original video. Reencoding with RipBot264 probably cropped them off.Have a good one,
neomaine
NEW! VideoHelp.com F@H team 166011!
http://fah-web.stanford.edu/cgi-bin/...teamnum=166011
Folding@Home FAQ and download: http://folding.stanford.edu/
Thanks for the quick replies, in response:Originally Posted by Baldrick
If I play the same MKV in VLC or MPC the aspect ratio is correct, its only WMP where its squished. It's just that they look better in WMP than the other players so I want to be able to use that instead. (Example: The black bars are actually black in WMP, they are grayish in VLC and MPC, this applies to all MKVs I play not just this particular file.)
image squished vertically and letterboxed
By blitzen in forum Newbie / General discussionsReplies: 1Last Post: 10th Aug 2009, 20:01 -
AutoMKV: 1080p or 720p MKV to smaller sized 720p MKV = choppy video!
By Quicky in forum Video ConversionReplies: 1Last Post: 12th Apr 2009, 20:23 -
Slow MKV 1080p Playback!
By The_WRATH in forum Newbie / General discussionsReplies: 3Last Post: 19th Aug 2008, 14:50 -
1080p mkv to 720p mkv?
By nick101181 in forum Video ConversionReplies: 1Last Post: 1st Jan 2008, 15:04 -
avi multiple audio - ffdshow, wmp.
By roscoerobinson in forum Software PlayingReplies: 2Last Post: 11th Apr 2007, 00:45
