VideoHelp.com Forum
    This has been keeping me up at night
    I have a program called convertxtodvd, I have another program called avideomux
    In avideomux I open the file (VTS_021.VOB.idx) I made the edit I wanted to do (cutting)
    after that I saved the project to my desktop, when I go into convertxtodvd it says something like unknown file format. So im thinking I have to convert the file first after I edit it? If so, How do I do that in avideomux? Or would I need a different seperate program to do that.
    Now....
    When I Save the VIDEO, it takes about 7 hours to finish (its a 4 hour video) only to go into convertxtodvd and the same thing happen again
    By the way, the exstention of the file after I save the video is... stat.fake
    I know im doing something wrong, please advise, thanks again.
    Avidemux project file and stats file can not be read by convertxtodvd
    Where is the final edited version being saved to by avidemux ... it's the file convertxtodvd should be given
    If you mean the after saving the video, it was saved to my desktop, its not saving it to convertxtodvd
    could I not just get a video converter and convert the edited file and then reopen the file with convertxtodvd?
    The simple questions is, how do I burn a Edited file using avideomux onto a dvd.
    To what format are you saving to in avidemux? if you use video and audio copy mode you can save it as a new mpg file without any conversion. THen import the mpg in convertxtodvd.
    There are two options as you said, Video and audio,
    What format should I save the video into , there are about 5 different formats of mpeg for the video mode
    and what should be saved for the audio?
    I also changed the exstention when I saved the project to project.mpeg, even though the file showed up as a little windows player icon, convertxtodvd still did not take the file.
    ok, I seem to solve the problem, I was able to burn the edited video using convertxto dvd. In avideomux I just messed around with the Video & sound mode, and format.
    Video mode- Mpeg-2 Requant
    sound mode- mp2 (lavc)
    format mode Mpeg-ps(A+V)
  1. Help: Video jumping/flickering when edited
    By toyota200x in forum Editing
    Last Post: 8th Nov 2010, 07:22
  2. Restoring edited video.
    By drummer in forum Editing
    Last Post: 9th Apr 2010, 05:57
  3. saving edited video
    By zulubase in forum Newbie / General discussions
    Last Post: 2nd Jun 2009, 20:48
  4. DVD burn for TV: hard disk camcorder mpeg-2 files edited in Vegas
    By h08 in forum Newbie / General discussions
    Last Post: 13th Nov 2007, 22:39
  5. Replies: 18
    Last Post: 15th Oct 2007, 22:40
