VideoHelp.com Forum
    I have a movie which was originally encoded with wrong AR so people look vertically shrunk. I would rather not reencode it and just use a software to make any player adjust the AR on the go. If I am not mistaken I understand mpeg 4 modifier does this. Is this correct. If so can anyone advise me how this is done?
    thanks
    Mpeg4Modifier will only work with Divx/Xvid AVI files. You simply open the AVI file with Mpeg4Modifier and set the PAR or DAR flags, then Save (as a new file).
    VLC
  4. Member Cornucopia's Avatar
    What format is the movie encoded in currently?
    DV? You could probably fix it with DVDate, Enosoft DV Processor, etc.
    Regular AVI? You could use AVIFrate or something, but a player wouldn't likely recognize it.
    QT? Depends on if you're going to be playing it w/ QT player or not (if so, a correcting DAR/PAR sizing adjustment and SaveAs Self-contained will work).
    MPEG1? MPEGSequenceMaker
    MPEG2? Restream
    There are others (these are ALL non-re-encoding methods)...
    Thanks for the reply guys. I will try mpeg4 modifier. I tried some videos before and did not know why it was not working. Video is xvid/mp3
  1. Resolution & Aspect Ratio
    By markf78 in forum Video Conversion
    Last Post: 11th Apr 2011, 14:17
  2. Resizing: Resolution and Aspect Ratio
    By roflwaffle in forum Video Conversion
    Last Post: 9th Apr 2011, 08:25
  3. Resolution vs Aspect Ratio
    By triptych in forum Newbie / General discussions
    Last Post: 7th Aug 2009, 07:23
  4. Aspect Ratio/Resolution Question
    By kidcash in forum Newbie / General discussions
    Last Post: 4th Nov 2007, 03:43
  5. Please explain Aspect Ratio and Resolution
    By slmnow in forum Newbie / General discussions
    Last Post: 21st Aug 2007, 19:14
