I have a issue with Windows 7 and dvdrw in vro mode from my dvd recorder. My issue is whenever i put the dvdrw in the drive. My computer sees it but won't let me see the contents on it. For me to edit the disc i gotta use like iso buster to get the stuff off to edit. When I click on the disc it just opens a player. I tried nero incd. No luck. Is this a known issue with windows 7? My dvd recorder brand is Toshiba D-R410. I tried google tons of searches and i found nothing to my problem. Vista has no issue reading dvdrws in vro mode.
I know about the vro mode. Its just i am unable to view the contents on windows 7 I havent tried to see if windows 7 will show the contents by right clicking and hit explorer. My friend is also having a issue too. She has windows 7 like me. I never had to right click on the cd and choose explorer before. I usely copy the stuff to the hdd or edit right off the disc but for some reason is that any programs i use is tell me the disc is empty. This just happens on windows 7 not vista.
So your saying you have 2 systems, one using windows 7 and the other vista ... yes or no
The right click part is in case windows explorer has gone to sleep for any reason when transportable media is being used ... dose not refer to "cd" ... as drives can be picky when it comes to reading dvd-rw and dvd-ram disc's
If the previous sentence is true and both windows systems are having the issue with dvdrw ... it is very common that these type of discs, especially the RW's need a lot more care if they are to be used more than a few times as faint scratch's basically foul them and after this they should be binned
Are these windows 7 systems new ... if so then I would suggest updating the firmware for those drives and reboot after that's done and try those discs once more ... if no good then those drives may either not like that brand of media or the drives them selves are junk and need replacing
There's also dvdisaster ... not tried it in windows 7... xp and vista yes ... but it can do no harm to try it -
I dont think i made myself clear my desktop witch has vista on it has no issues with any dvdrw in vro mode. My laptop witch has windows 7. Has the issue of viewing the contents of windows 7. My laptop windows 7 have no issues with dvdrw in video mode. The laptop is brand new i had it only like 2 months. It works great. I understand what your saying but it doesnt seem to help me out. Is there like a packet reader for 7 other than nero incd that may help me out on my laptop?
I fixed this problem. Since i can see it the vro in any editor. I just have tmpgenc mpeg editor extact the vro to mpeg from the dvd without converting it.
Windows XP Mode in 7 Question
By Frank-0-Video in forum ComputerReplies: 7Last Post: 30th Aug 2011, 21:37 -
.VRO files & windows media player
By jon22330 in forum Video ConversionReplies: 6Last Post: 28th Dec 2010, 13:06 -
Virtual Windows XP mode with W7 Home Premium?
By neworldman in forum ComputerReplies: 3Last Post: 4th Oct 2010, 12:45 -
How do I alter a VRO file so Windows Movie Maker will allow me to edit
By povie in forum Newbie / General discussionsReplies: 7Last Post: 7th Oct 2009, 17:27 -
DVDRW not recognized by Windows XP
By bmwracer in forum ComputerReplies: 38Last Post: 11th Sep 2008, 20:33
