VideoHelp.com Forum
  1. I read about all hacks but it is only for DVD and I dont even watch that shit anymore...IS THERE any BD player that is reg free on BD discs as well? Is there any player that can be hacked for this? Or anyone selling hacked players ans so on?
    Chris
    Cinema Replicas
  2. Member hech54's Avatar
    You can buy one that has been taken apart and had components removed and/or replaced - soldered - back into place....yes.
    There are a few region free BluRay players. However, what "region free" for BluRay means is that you can change the region to A, B or C at any time with a code. There is no setting for all regions for BluRay discs like there is for DVDs.
    None of the manufacturers are allowed to make BluRay players that can be made region free, so that means that you either have to put on hacked firmware after purchase or you have to buy a player that has modified hardware that the seller has installed for you.
    Oppo makes a player that can be made region free with new firmware you can install. Momitsu makes a player that some sellers have installed modified hardware into. I've heard of a couple of other players (not by big manufacturers) that are available in the UK that can also be made region free, but as I don't live in the UK I don't remember the names.
    As you don't say where you live, you could try Googling for Momitsu 899, Curtis 1100 (both the same player but with different badges - make sure the Curtis variant is the BD Live 2 version with the lan port), or the Momitsu 799 (smaller, cheaper player with less connectivity than the 899)
  1. Replies: 8
    Last Post: 21st Dec 2011, 19:31
  2. Ntsc BluRay players play PAL(region-free) dvdr?
    By spiritgumm in forum DVD & Blu-ray Players
    Last Post: 22nd Nov 2009, 18:48
  3. are there any blu-ray players that can be made region free for dvd's?
    By CODEWERKX in forum Newbie / General discussions
    Last Post: 25th Sep 2009, 13:26
  4. Soniq DVD players region free hack
    By sshipway in forum DVD & Blu-ray Players
    Last Post: 5th May 2009, 16:58
  5. Question: Region Free DVD Players
    By SentaiFan in forum DVD & Blu-ray Players
    Last Post: 13th May 2007, 03:07
