Hi Every body,
I am using Windows Media encoder 9 to broadcast live channel in internet.
By using mms i am doing this.
Some of the customers are interested to see my channel in internet.
But they are about 14:30 hours back to my original channel broadcast time.
So, i should play my live TV after 14:30 hours from my time. May be this is time switching.
Is there any way to do that using WME9 or any other way??
Help appreciated.
Thanks in advance
Thread: Live Stream time switching
Record the stream and stream later? You can do it in wme.
Dear Admin,
can you post how i can do that.
Thanks in advance.
Dear Admin,
I am already Live streaming using Windows media encoder 9.
But i do not have an idea about how i can do time shifting using WME9.
Can you provide me how i can do that
Thanks in advance.
Create two WME session profiles - one for your live broadcast and simultaneous 'archiving' as a WMV file and a second for broadcasting the 'archived' file later on.
Double-click on the session files (.wme extension) or tell Windows to run the file at a specified time. You will probably want to change the archived file name. To do that, just edit the session file in Notepad. Here's a snippet:
It is obvious where the change needs to be.Code:<?xml version="1.0"?> <WMEncoder major_version="9" minor_version="0" Name="WMEncoder7091" SynchroniesOperation="0" > <Description /> <Attributes > <WMENC_STRING Name="WM/ParentalRating" /> </Attributes> <SourceGroups > <SourceGroup Name="Source 1" > <Source Type="WMENC_VIDEO" Scheme="file" InputSource="C:\Documents and Settings\John\My Documents\Example.avi" PixelAspectRatioX="1" PixelAspectRatioY="1" > <UserData > </UserData>
Hope this helps you.
John.John Miller
enosoft - high performance tools for music and video
Home of the Enosoft DV Processor - Free for personal use!
How to Stream Live TV to my website??
By afghanistan-culture in forum Video StreamingReplies: 8Last Post: 29th Feb 2012, 20:00 -
How to time shift a live stream?
By yalag in forum Video StreamingReplies: 13Last Post: 2nd Feb 2012, 16:22 -
How to stream live mms click from one mobile to another mobile live
By rahul1971 in forum Video StreamingReplies: 0Last Post: 19th Mar 2010, 06:14 -
Live Video Switching Computer Editing
By JJ - Tampa in forum CapturingReplies: 1Last Post: 14th Jul 2008, 21:36 -
Timeshift Anyone?? WME and LIVE Stream and I want to time shift.....
By djsashaz in forum Newbie / General discussionsReplies: 3Last Post: 4th Jan 2008, 15:50
