  1. Member Amanda28's Avatar
    Hello
    I'm trying to broadcast live over the internet and I really need some help.
    I'm using a Toshiba Camileo H2o camera . The resolution of this camera : VGA, WVGA60,QVGA, HD(720p) and HD(1080p). I'm using Composite input and video standard Pal-BDGHI ( that doesn't mean anything to me , but maybe it does to you).
    Anyway I played with resolutions but I don't seem able to get the video to fit into a 324x240 window ( CamZoomer , Splitcam and others) corectly, even if the camera has this resolution. What happends is that in most resolutions there are 2 black lines on top and at the bottom of the video (just like new line cinema).
    This happends with all resolutions I've tried ,except when in VGA resolution where there are smaller lines on the right and the left of the video.
    So please help. Is the camera bad? Is the capture card bad? What should I do?
  2. Member edDV's Avatar
    Why a 324x240 window? Why not CIF 352x240? CIF PAL is 352x288.
    The Osprey 211 wants analog SD input over composite or S-Video. The camera should be outputting 4x3 SD analog video. For no borders that means digital cameras should be set to 704x480i/29.97 (NTSC) or square pixel 640x480. Possibly 768x576 will work.
    Left and right stripes result from setting camera to 720 rather than 704.
    http://www.kiva.org/about
  1. Encode MPEG4 with Osprey Capture Card
    By john_doe in forum Capturing
    Last Post: 3rd Feb 2005, 11:19
  2. Osprey 2000 Hardware Capture Card
    By thor17usa in forum Capturing
    Last Post: 26th Jan 2004, 16:56
  3. Osprey 200 capture card
    By in forum Capturing
    Last Post: 28th Sep 2001, 22:13
  4. Osprey 200 Video Capture Card....
    By HelpMePlease in forum Capturing
    Last Post: 5th Aug 2001, 16:46
  5. Selling Osprey 200 Capture Card...
    By scottnic in forum Capturing
    Last Post: 26th Jul 2001, 02:41
About   Advertise   Forum   RSS Feeds   Statistics   Tools
