VideoHelp.com Forum
    Hi guys,
    I need help fixing my friend's corrupted video file that she can't open.. After browsing through all the webpages I find this forum most promising, hopefully I can get some help here ><
    The corrupted file is saved in .mov file, somehow it's the only file that doesn't open. When I tried using QT7, error code "2048 - Couldn't open the file because it is not a file that Quicktime understands" appears. I used MediaInfo it couldn't seem to detect the container info except its size and that it's in Quicktime format.
    I have tried all sorts of recovery tools and media players (e.g. VLC, MPC, SMPlayer...too many to recall) but none that helped to recover a working file, so I have given up on that.
    So now...I have decided to manually hexedit the file by copying the footer (which seems to be missing from the bad video) from a working video taken using the same camera. However, I need help in detecting where exactly the footer of the working file starts from...
    I'm a beginner to hex-edit, and I only starting touching it because I want to fix this video. It is sentimental and means alot to my friend. Please, help me!
    Here is a screenshot of both the hex codes of working and non-working file, don't know if it helps but I hope you can point me in the right direction...All helps are VERY MUCH appreciated... Tell me if you need more information, thanks!
    This is start of file:
    This is end:
    Geraldine
    Welcome darkie1213
    Yikes! ... good start ... anyway
    Some handy info > inside mov
    More > Atoms, Boxes, Parents, Children & hex ... basic structure design and characters
    Be targeting all below "moov" ... it looks aka ... completely shot ... but then I cannot tell if "moov" exists in the none working file from those shots as it would be higher in the data
    Hi Bjs, thanks for the links I'll look through them later =)
    The "moov" exists in the nonworking file about halfway up the data, does that mean I should copy everything below "moov" in working file to the nonworking file?
    p.s. I forgot to mention the nonworking file size is about 120mb
  1. Nikon Coolpix corrupted .mov video file repair
    By darrenpj in forum Video Conversion
    Last Post: 31st Mar 2012, 17:15
  2. HELP! Damaged/Corrupted MOV file.
    By neil wilkes in forum Editing
    Last Post: 13th Nov 2011, 07:09
  3. I have a corrupted Quicktime MOV file I need to fix.
    By Videogamer555 in forum Restoration
    Last Post: 5th Mar 2011, 00:51
  4. Corrupted MOV file shows up as MPG
    By jblc in forum Video Conversion
    Last Post: 10th Jan 2010, 14:15
  5. Corrupted converted .mov files
    By Nintendo Fan in forum Editing
    Last Post: 21st Jan 2009, 18:26
