hello everybody! first time here and first time making dvd's.
I have a bunch of vob files that were recovered from bad disks. now I'm trying to make dvd iso's out of them.
I'm doing that by using vobedit and ifoedit to create what dvdshrink would need to re-author a dvd. menus, etc. not important.
so you know what I'm doing, here's a script I made to follow:
I'm happy with making only 1 movie per iso, I could fit 2 or 3 movies per dvd iso but I don't need to get that fancy.1. recover video files off disk
2. put only vob files in a directory named VIDEO_TS, excluding the first small vob file
3. rename in sequence VTS_01_00n.VOB
4. run vobedit
click "open" button, open first file
click Edit, "join clips", select 2nd file, next dialog box should say first vob is number: 1 (is appending onto that)
vobedit converts the files, automatically contuining in sequence. output named VTS_01_n.VOB
first vob=1, unless doing something fancy
close vobedit
delete or move source files from directory.
5. run ifoedit
click "create IFOs" button
open the first VOB file from vobedit output. make sure that "same as source" is checked.
ifoedit reads VOB's and makes IFO's.
items appear in top window of ifoedit. first one should say ....VIDEO_TS.IFO. click on it.
in bottom window, double click VTS_1 Audio ..., change languadge to english, click ok. save and confirm when asked to overwrite.
repeat for second line in top window.
click "get VTS sectors" button, click Yes, click thru ok's
close ifoedit
now in VIDEO_TS folder there is a full set of files. compile with dvd authoring program as normal. The resulting DVD will contain one large Video sequence, no chapters nor menus, skipping can be done per 5 minutes.
I go through all of the above with no problems but the first thing I do in dvdshrink is open the TS_Video folder, and it tells me this:
"dvdshrink has encountered an error and cannot continue. invalid data in file C:\VIDEO_TS\VTS_01_2.VOB"
I can be working with 2 or 3 or 4 vob's, but it's always the last vob that dvdshrink quotes.
the vob's themselves each play in VLC Media Player, irregardless of whether they have been through vobedit or not. they don't seem to be corrupt.
I don't know what I'm doing wrong, but to make things more complicated, it DID work for two movies. I double checked, did them over again, I was not doing anything different than the other movies.
what might be the problem?
Welcome Dr_Sanguinary
Steps 3 and 4 is what let you down
Vobs contain information regarding vob id / cell id ... and each must contain the same number of streams ... some programs will detect the order is incorrect if it was done so and throw the error
Use vobedit to demux each vob into different folders then use these streams in your dvd authoring program of choice and you won't have issues
if I demux the vobs, then don't I still have to join the video and audio streams in their respective folders? and what about the rest of the missing files, such as .ifo etc?
basically, if I need to demux, I'm lost as to what to do.
Making DVDs from backups of VOB files
By kirklt in forum Authoring (DVD)Replies: 1Last Post: 26th Aug 2009, 08:52 -
DVD Demuxer tool making 0kb .VOB files
By Madvillain in forum DVD RippingReplies: 5Last Post: 6th Jul 2009, 04:11 -
Making a DVD menu from .VOB files created by FAVC?
By whatever911 in forum Authoring (DVD)Replies: 9Last Post: 16th Feb 2009, 03:13 -
making movie from many mepg/vob files
By volam in forum EditingReplies: 3Last Post: 10th Apr 2008, 10:33 -
Will joining two AVI files cause problems later in making DVD by Nero 6?
By wayney in forum EditingReplies: 1Last Post: 17th Jun 2007, 20:18
Statistics
Newest guides
Latest tool updates
New media comments
