VideoHelp.com Forum
    This may sound like a dumb question but i haven't any clue about technology. I have found hacks for my Toshiba SD4100 dvd player to play UK dvds with people stating that it allowed them to play the dvds here, does that mean that the player is both NTSC and PAL compatible?
  2. Member midders's Avatar
    AFAIK all modern DVD players support both PAL and NTSC as part of the DVD standard.
  3. Member hech54's Avatar
    WRONG.
    DVD player hacks have ZERO to do with PAL/NTSC....they involve region codes.
    The original poster is in NTSC territory. They will need to hack the player region free
    AND hope the player can convert PAL to NTSC.
    midders is not really correct and quite possibly horribly wrong for people who live in NTSC countries like Canada.
    DVD players can easily support PAL and NTSC and convert either to the other in hardware. Whether the player does so or not is up to the manufacturer. Many DVD players sold in Canada and the USA are completely unable to play or convert PAL video. Some will play PAL and NTSC but not convert it, so PAL DVD = PAL video output. Typically that is very bad for people in North America. Most North America TVs can't display PAL video correctly.
    So since you found a hack for your player, you are incredibly lucky and probably it means that the player can convert PAL DVD to NTSC video output, but you'll have to test it to see. Be sure that you check your DVD player menu and see if you have an option to set the video output to NTSC. If this can be changed it is often set to either "ANY" or "MULTI" by default and usually that won't work on North American TVs. If you cannot set the video output of your DVD player and your TV can't display it correctly then your player does not convert from PAL input to NTSC output and your TV can't display PAL video.
    midders is in the UK where the situation is completely different and the vast majority of DVD players and TVs are capable of either displaying NTSC or at least converting NTSC video to PAL output. But there is no requirement at all for DVD players to support both PAL and NTSC and some players only support one.
  5. Member midders's Avatar
    Lucky me
  6. Member victoriabears's Avatar
    Region free is not really the BIG issue, the ability to play PAL on a NTSC TV is, but it is easy enough to get a player that does, Philips/ Pioneer etc all easilly bought from on line stores, and they seem to be getting cheaper.
    Make a backup of any dvd and the backup is then region free.
    PAL/NTSC problem solver.
    USED TO BE A UK Equipment owner., NOW FINISHED WITH VHS CONVERSIONS-THANKS
  1. Converting DVDs from Region 1 (NTSC) to Region 2 (PAL)
    By Astronautilus in forum Authoring (DVD)
    Last Post: 10th Feb 2012, 04:35
  2. Convert PAL Region 2 DVD to NTSC Region-Free DVD?
    By wizoomer95 in forum Video Conversion
    Last Post: 6th Aug 2011, 21:10
  3. Portable DVD player. Region free. Pal/NTSC
    By jtrinc in forum Portable Video
    Last Post: 16th Aug 2010, 09:28
  4. Does making a dvd player region free also allow PAL to display on NTSC?
    By dizmack in forum Newbie / General discussions
    Last Post: 25th May 2010, 19:50
  5. Ntsc BluRay players play PAL(region-free) dvdr?
    By spiritgumm in forum DVD & Blu-ray Players
    Last Post: 22nd Nov 2009, 18:48
