VideoHelp.com Forum
Results 1 to 10 of 10
    As the title says, I am having problems getting my DVD Player to play DVDs that I create from my PC. I am using DVD+R media from Verbatim and my DVD Burner is Liteon LH20-A1A. I have used several programs in an attempt to see if the results vary but the result is the same - DVDs that freeze, slow down and are choppy on my Onkyo DV-SP302 player. I have tested the DVDs in the Liteon Burner and they play fine. The software that I am using is DVD-Flick.
    I was looking at the logfile that DVD-Flick creates and I did notice this statement. Would it help if I lowered the bitrate? DVD-Flick allows me to do that. Any other ideas? I am posting the info from media info at the end of this post.
    [NULL @ 0x3ec8c0]Invalid and inefficient vfw-avi packed B frames detected
    Seems stream 0 codec frame rate differs from container frame rate: 23.98 (65535/2733) -> 23.98 (24000/1001)
    Input #0, avi, from 'E:\Movies\XXXX 2009 DVDRip XviD-Dubby\Bruno 2009 DVDRip XviD-Dubby.avi':
    Duration: 01:21:27.88, start: 0.000000, bitrate: 1203 kb/s
    Stream #0.0: Video: mpeg4, yuv420p, 640x336 [PAR 1:1 DAR 40:21], 23.976 tbr, 23.976 tbn, 23.979 tbc
    Stream #0.1: Audio: mp3, 48000 Hz, stereo, s16, 128 kb/s
    Seems stream 0 codec frame rate differs from container frame rate: 29.97 (30000/1001) -> 23.98 (24000/1001)
    Input #1, mpegvideo, from 'C:\Documents and Settings\Bill Patterson\My Documents\dvd\0.0.m2v':
    Duration: 01:21:27.79, bitrate: 6988 kb/s
    Stream #1.0: Video: mpeg2video, yuv420p, 720x480 [PAR 32:27 DAR 16:9], 6988 kb/s, 23.976 tbr, 23.976 tbn, 29.970 tbc
    Output #0, ac3, to 'C:\Documents and Settings\Bill Patterson\My Documents\dvd\0.0.0.ac3':
    Stream #0.0: Audio: ac3, 48000 Hz, stereo, s16, 192 kb/s
    General #0
    Complete name : E:\Movies\XXXX 2009 DVDRip XviD-Dubby\Bruno 2009 DVDRip XviD-Dubby.avi
    Format : AVI
    Format/Family : RIFF
    File size : 701 MiB
    PlayTime : 1h 21mn
    Bit rate : 1198 Kbps
    Writing application : VirtualDubMod 1.5.10.2 (build 2540/release)
    Writing library : VirtualDubMod build 2540/release
    Video #0
    Codec : XviD
    Codec/Family : MPEG-4
    Codec/Info : XviD project
    Codec settings/Packe : Yes
    PlayTime : 1h 21mn
    Bit rate : 30 Mbps
    Width : 640 pixels
    Height : 336 pixels
    Display Aspect ratio : 1.905
    Frame rate : 23.976 fps
    Resolution : 24 bits
    Bits/(Pixel*Frame) : 0.205
    StreamSize : 151
    Audio #0
    Codec : MPEG-1 Audio layer 3
    Codec profile : Joint stereo
    PlayTime : 1h 21mn
    Bit rate : 30 Mbps
    Bit rate mode : CBR
    Channel(s) : 2 channels
    Sampling rate : 48 KHz
    Resolution : 16 bits
    StreamSize : 60.0
    Writing library : Xing (new)
    [/quote]
  2. Member dialysis1a's Avatar
    DVD Flick doesn't burn. It calls on ImgBurn to do the actual burning. Posting the ImgBurn log may help.
  3. Man of Steel freebird73717's Avatar
    Verbatim is good media so that should rule bad media.
    Have you tried playing the dvd in another stand alone player? That player could just be picky about dvdr's.
    Donadagohvi (Cherokee for "Until we meet again")
    My Video Tools :: Free Security Software :: Ubuntu Antivirus Rescue CD
    Use DVD-R ... some players have issues with + media
    Here is the Imgburn output. Looks like there are some warning messages towards the end.
    I 08:42:08 ImgBurn Version 2.4.2.0 started!
    I 08:42:08 Microsoft Windows XP Professional (5.1, Build 2600 : Service Pack 3)
    I 08:42:08 Total Physical Memory: 2,096,172 KB - Available: 1,282,388 KB
    I 08:42:08 Initialising SPTI...
    I 08:42:08 Searching for SCSI / ATAPI devices...
    I 08:42:08 Found 1 DVD±RW/RAM!
    I 08:42:09 Operation Started!
    I 08:42:09 Building Image Tree...
    I 08:42:09 Checking Directory Depth...
    I 08:42:09 Calculating Totals...
    I 08:42:09 Preparing Image...
    I 08:42:09 Checking Path Length...
    I 08:42:09 Contents: 9 Files, 2 Folders
    I 08:42:09 Size: 4,470,124,544 bytes
    I 08:42:09 Sectors: 2,182,678
    I 08:42:09 Image Size: 4,470,734,848 bytes
    I 08:42:09 Image Sectors: 2,182,976
    I 08:42:09 Operation Successfully Completed! - Duration: 00:00:00
    I 08:42:09 Source File: -==/\/[BUILD IMAGE]\/\==-
    I 08:42:09 Source File Sectors: 2,182,976 (MODE1/2048)
    I 08:42:09 Source File Size: 4,470,734,848 bytes
    I 08:42:09 Source File Volume Identifier: DVD Video
    I 08:42:09 Source File Application Identifier: IMGBURN V2.4.2.0 - THE ULTIMATE IMAGE BURNER!
    I 08:42:09 Source File Implementation Identifier: ImgBurn
    I 08:42:09 Source File File System(s): ISO9660, UDF (1.02)
    I 08:42:09 Destination Device: [3:1:0] LITE-ON DVDRW LH-20A1L BL06 (D (ATA)
    I 08:42:09 Destination Media Type: DVD+R (Disc ID: MCC-004-00) (Speeds: 2.4x, 4x, 6x, 8x, 12x, 16x)
    I 08:42:09 Destination Media Sectors: 2,295,104
    I 08:42:09 Write Mode: DVD
    I 08:42:09 Write Type: DAO
    I 08:42:09 Write Speed: 4x
    I 08:42:09 DVD+R Reserve Track: No
    I 08:42:09 Link Size: Auto
    I 08:42:09 Test Mode: No
    I 08:42:09 OPC: No
    I 08:42:09 BURN-Proof: Enabled
    W 08:42:13 DeviceIoControl(FSCTL_LOCK_VOLUME) Failed! - Reason: Access is denied.
    W 08:42:13 DeviceIoControl(FSCTL_DISMOUNT_VOLUME) Failed! - Reason: Access is denied.
    I 08:42:14 Book Type Setting: DVD-ROM
    I 08:42:14 Advanced Settings - Force HT: No, Online HT: No, OverSpeed: No, SmartBurn: Yes
    I 08:42:14 Filling Buffer... (40 MB)
    I 08:42:15 Writing LeadIn...
    I 08:42:43 Writing Session 1 of 1... (1 Track, LBA: 0 - 2182975)
    I 08:42:43 Writing Track 1 of 1... (MODE1/2048, LBA: 0 - 2182975)
    I 08:56:10 Synchronising Cache...
    I 08:56:14 Closing Track...
    I 08:56:16 Finalising Disc...
    I 08:56:34 Operation Successfully Completed! - Duration: 00:14:25
    I 08:56:34 Average Write Rate: 5,410 KB/s (3.9x) - Maximum Write Rate: 5,618 KB/s (4.1x)
    I 08:56:34 Close Request Acknowledged
    I 08:56:34 Closing Down...
    I 08:56:35 Shutting down SPTI...
    I 08:56:35 ImgBurn closed!
    Any other ideas? I tried using DVD-R and the playback was better but still had pauses. I also cleaned the heads on the DVD.
    I think we've ruled out disc media, so let's focus on content. Your source file is an xvid avi. There may be something wrong with that, or else the way it was converted to mpeg2.
    However, the .avi seems to be a DVD rip. In that case, you should go back to your original DVD source and not use the .avi file.
    try another media brand...i know verbatim is rock solid but i had this exact same issue with my lite on 20a(which is now dead) and i tried other media and it was usually a bad batch of media or the drive going bad...not imgburn...may also try app like avs2dvd instead of dvdflick
  9. Man of Steel freebird73717's Avatar
    I still say it's a flaky dvd player. Try playing it in another player. If you don't have one then ask to play it on a neighbors or relatives.
    It's too difficult to say with certainty. Your media should be good and you are burning at 4x speed which should be fine (some weird problems are sometimes reported when burning at faster speeds). I don't trust tools like DVD Flick much. So it could be a problem with the source, or DVD Flick doing a bad job or your media or your DVD player. freebird73717's suggestion is excellent. Try the disc elsewhere as if it plays fine elsewhere it's definitely your player's problem.
    By the way, cleaning doesn't always fix problems. You can try it, but sometimes the only solution is repair/replacement.
  1. Re-Encoding XviD for playback on Stand alone player.
    By LoveHateMachine in forum Newbie / General discussions
    Last Post: 15th Nov 2009, 19:39
  2. Problem With Stand alone DVD player and Burned Dvds
    By tealmarlin in forum Newbie / General discussions
    Last Post: 25th Jan 2009, 14:02
  3. Help with playback on DVD player with burned DVDs (Codec and format)
    By enjikari in forum Newbie / General discussions
    Last Post: 28th Sep 2008, 02:33
  4. Replies: 0
    Last Post: 27th Oct 2007, 10:10
  5. Some burned dvd's freeze every few seconds on playback. help?
    By jessandjeff123 in forum Newbie / General discussions
    Last Post: 14th Jun 2007, 12:38
