I'm thinking of getting this camcorder.
Sanyo VPC-CG10 HD Flash Memory Camcorder w/5x Optical Zoom (Black)
http://www.amazon.com/Sanyo-VPC-CG10...8411731&sr=8-1
Sanyo Xacti VPC-CG10 10MP HD Flash Camcorder (Red)
http://www.radioshack.com/product/in...ductId=3558934
I do not want to re-encode the MOV files to another format to edit, encoding the files to another format is another step plus extra time to encode.
Thanks.
No, you won't find these cameras on Adobe's support list. Even if they were AVCHD format, they would edit sluggishly even on a quad core.
H.264 really needs conversion to a digital intermediate.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about
Found this
zi8 mov files in sony vegas movie studio 9
http://www.youtube.com/watch?v=TX-u59-YUcA
MOV to mp4 tutorial
http://www.youtube.com/watch?v=p04K3ArxUjc
That guy doesn't know his 720p 30 from his 720p 60 from his 1080i. The Kodak z18 can do 1280x720p 60 (59.94) fps and this is what you want for a cheap (plastic lens) hand held camera.Originally Posted by vatkat234
1080p 30 has half the motion samples and not enough better image resolution because of the cheap optics. Consider 1080p 30 only for tripod stabilized landscapes.
The Sanyo only does 720p 30 which is fairly useless except for shooting material for the web.
Vegas Pro can edit 1280x720p 59.94. I doubt Vegas Movie Studio will.
The problem with most of these small cameras is they don't allow enough bit rate for h.264 1280x720p/60. The Kodak z18 spec isn't clear on bit rate short of downloading the manual. Be aware that desirable 24 Mb/s gets you into Level 4-6 flash media.Recommends: Kiva.org - Loans that change lives.
Footage captured in Sony Vegas compatible with Adobe Premiere Pro?
By snoutproductions in forum Software PlayingReplies: 15Last Post: 21st Jan 2012, 10:28 -
How to edit .WTV files from Hauppauge HD-PVR (H.264/AC3) in Adobe Premiere
By milOtis in forum User guidesReplies: 2Last Post: 12th Apr 2010, 04:04 -
Sony Vegas 9 Professional or Adobe Premiere CS4 for PC
By apollo1980 in forum Newbie / General discussionsReplies: 5Last Post: 26th Jan 2010, 14:36 -
Sony Vegas 7 doesn't let *.mov & *.avi files be imported into project..
By koldun in forum EditingReplies: 5Last Post: 1st Jul 2008, 15:04 -
your opinion plz: adobe premiere or sony vegas
By jrahma in forum Newbie / General discussionsReplies: 1Last Post: 1st Oct 2007, 05:38
Statistics
Newest guides
Latest tool updates
New media comments
